Stock Radio - Two plugs in the rear - Diesel Forum - TheDieselStop.com
Old 09-21-2005, 03:06 PM   #1 (permalink)
I have a stock Ford radio in my 2001 PSD....single CD/Cassette/AM/FM. The factory wiring goes into a conector (on the back of the radio) which has 2 rows of pins. There is another slot for a connector (on the back of the radio) which has 3 rows of pins...this 3-row connector slot is not used on mine.
Any of you know what the connector with three rows of pins is for?
I want to add a Sirius satellite radio and am wondering if it can be done through this connector....or will I have to buy a new after-market radio?
Florida ED
2011 Suzuki Burgman 650cc Rice Rocket Scooter 49 MPG, 120+ MPH, & 2009 Honda Shadow 750cc 51 MPG, 100+ MPH
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 159K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 98K miles headed to 150K stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline
Old 09-21-2005, 04:57 PM   #2 (permalink)
Re: Stock Radio - Two plugs in the rear
The "unused" 20-pin recepticle allows you to do exactly as you're thinking, and play your satellite radio through your headunit. I installed one in my 2002 6-cd player (Also works for the single CD/Cassette HU) for my MP3 player, and it works GREAT:
Purchase a PIE adaptor FRDN-AUX (Precision Interface Electronics). Here's a description of what it does:
The PIE FRDN-AUX Auxiliary Input Converter connects to the CD changer data port of your factory radio to create an external auxiliary input that has a pair of left and right RCA audio inputs. With this converter installed, you can connect any external audio device that has an audio output directly to your factory radio without using an FM modulator and hear the audio from your factory sound system. The FRDN-AUX plugs directly into the rear of the headunit using the 20-pin connector.
Here's a link to one retailer:
http://www.logjamelectronics.com/piefrdnaux.html
They're about $70
Phil
2002 F350 Lariet 4x4 CC SB 7.3
PhilF350 is offline
Old 09-21-2005, 05:03 PM   #3 (permalink)
jetskier's Avatar
My Photos: (23)
That connector is for a 6 disc changer. But there are adaptors to tap it for adding auxillary audio gadgets like Sirius. PIE comes to mind.
You'll get better sound out of an aftermarket deck, but for a simple direct wired solution, these adaptors work
2000 F350 XLT 4x4 CC LB SRW, PSD, 4R100, MSOF, 3.73 TrueTrac, OTC, wired keypad, AIC, DRL, Gauges, DP F6 Live Tuned, Ford AIS w/ sleeve & Zoodad, ATS housing, 31-row trans cooler, HPX line, Magnaflow & BrakeSmart.
jetskier is offline
