Super Duty Stereo Removal - Diesel Forum - TheDieselStop.com
Old 01-04-2009, 07:56 AM   #1 (permalink)
OK, I tried the Ford radio removal tools. I had the right side unclipped, but the left side would not release. After numerous tries, now the right side wont release and it seems as though the spring clips wont release at all. When I put in the tools I don't feel the clips like I did at first try. Is it possible to screw up the clips with just the removal tools???
I want to keep the factory radio so I dont want to destroy it.
Any experts out there who have had the same problem???
HELP!
2002 F-250 Crew Cab, Short Bed, 4X4, 4R100
Tuned: Yes
Transmission: Yes
Exhaust: Yes
Intake: Yes
Turbo: Yes
Injectors: Yes
SeaStroke is offline
Old 01-04-2009, 08:24 AM   #2 (permalink)
Well, it lookslike I posted prematurally. After searching, it seems that I am not the only one who has had problems. I hope I don't have to use a crow bar!!!!!!!!!!!!!!!!!!!
Tuned: Yes
Transmission: Yes
Exhaust: Yes
Intake: Yes
Turbo: Yes
Injectors: Yes
Old 01-04-2009, 08:43 AM   #3 (permalink)
The tools work by depressing the locking pins on the side of the radio. If you pushed the tools too far into the radio, they won't release the locks. Remove the tools, and reinsert. You should here them click when they go in about 1/2 inch. You may have to 'play" with the tools to get tehm to rleseae the locks.
It's a trial and error type thing. Whatever you do, don't force the tools. If they break, you have to remove th whole dash. No fun.
marc
2005 F-250 Supercab 4x4 Lariat long bed 6 speed, Vegistroke V3 WVO system, integrated brake controller, upfitter switches, TTM, South Texas Outfitters custom front end replacement, Whelen Liberty LED lightbar, Whelen Dominator LED front bar, hidden front strobes, rear LED's and strobes, Rhino liner, Whelen 200 watt siren, Havis Consolidator console, and other hidden goodies. Pictures are in "Shoebox" album.
http://community.webshots.com/user/vtfireftr
VTFireftr is offline
Old 01-05-2009, 02:38 PM   #4 (permalink)
Yeah it can be a bit tricky... I've done three different trucks like that and had no problems.
Ray21 is offline
Old 01-05-2009, 03:09 PM   #5 (permalink)
kavanrose's Avatar
My Photos: (9)
Easy way I do this is the front of the dash just snaps off. pull a couple of wires and the radio comes out with it. Unplug wires behind radio and take the whole thing out.
kavanrose is offline
Old 01-05-2009, 05:35 PM   #6 (permalink)
marc
Yea, I tried everything, I tried to put the tosl in just a little bit and never felt them touch a thing. I put them in a little further, and while I felt them touch what I thought was the clip release, I never got the damn thing to come out. Is it possible to screw up the clips with the tools alone? I can't believe I could damage them that bad with the limited movement you get through the holes.
Tuned: Yes
Transmission: Yes
Exhaust: Yes
Intake: Yes
Turbo: Yes
Injectors: Yes
Old 01-06-2009, 11:07 AM   #7 (permalink)
john_from_ict's Avatar
I put the two tools in the corresponding holes on the faceplate until I hear and feel them touch the clips. Then I use my thumbs to press outwards on the tools themselves while I also pull the radio out. Sounds stupid but it works for me, unless one or both of the clips is damaged.
2001 F250 CC SB 7.3L, AT, Lariat (4" exhaust,Marinco plug,Fumoto valve, Kwik filter,Quadzilla Commander Digital Gauge pod on A-pillar, AIH Delete, SS HPX, Zoodad mod, Shimmed FPR, Heater control valve mod, acetoned badges, billet grill, 2002 headlights w/ GOS harness, 2008 TT mirrors with Explorer defrost switch for mirror heat)
john_from_ict is offline
Old 01-06-2009, 12:26 PM   #8 (permalink)
I have damaged the clips on mine by using to much force. They will no longer unlock with tool. What I did was pop the dash out a little then get a long screwdriver and push the clips in from behind the dash. Works great and slides right out. Plus while pushing in on the clips you can put a little pressure on the radio to push it out. I unlock one side then the other and push the rest of the way. Hope this helps
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, Triple disk converter, whicked wheel, 203 t-stat, High pressure bypass, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom 86gal AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
