1999-2007 Upgrades and Aftermarket - GeneralUpgrading or adding OEM or aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
You would be better off finding a stock 30mm rear sway bar from a junk yard..best fitting and works great
What to get/ask for at the junkyard ? Are the F250's and F350's the same 30mm ? Does it matter if it was DRW ?
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
The down side, my Ex never had a rear bar. So I need all the hardware as well. Are you guys saying the same bar and hardware for the F250/F350 are the same for my Ex?
I put a Hellwig bar under my 03 ex. It made a major difference in handling. It was an easy install. It came with all of the parts needed to install it.
I recommend it.
See my sig.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
I don't know either, but it sounds like it.....I hope Caryt will jump back in and tell us the deal.
Hi I am new here but here's what i have.
I just bought a lifted 4x4 diesel 7.3.It has a bunch of upgrades such as tvs stereo steps that come out etc.here is my problem it sways all over on the freeway.I have read other posts but this truck has a 8 inch lift coil over spring suspension in front with heavy duty drag links and all bells and whistles 22 inch rims 37 inch tires its re geared and looks like it was dona all legate.I changed all bushings and drag link checked air in the coil overs lubed what needed to be lubed and this thing still sways mostly in rear.It doesnt have any beef in back like ladder bars sway bar or even heavy duty shocks...I know its a mammoth but i want to stiffen it up and make it feel strong straight and reliable.WHAT DO I DO? Mymain concern is all the sawy in the back.Also can you turn off the rev sensor the guy said he did but i think its broke THANk you very much.
You might want to start a new thread for this. It is a new issue and you might get more responses as a new issue. But, that said......
Pick up? or Excursion? What year? How many miles on it? How old is the steering damper. I do not know about the shocks but I would guess the steering damper may wear out.
I do not have a lift, much less 8 inches, but my Ex was sloppy in the front until i took it in for a front end alignment. I had to take it back because of the looseness of the front end control. They tightened up the track bar bolts and that took care of it. So, depending on the year and miledge you might want to walk (yes I said walk- AN 8" LIFT!?!?!?!) around under the truck and tighten things up. Remember that some of the torques are pretty tight. MOst are normal. But the track bar bolt torque for my 03 Ex is 450 foot pounds. So, if they didn't get them torqued tight enough when the install was done by now you may have some loose connections.
Thanks its an excursion we went through the whole thing tightened it all up and replaced the drag link.It had leafs in front but they put the skyjacker coil overs.It needed alot of love but now is great, its just going down the road it wanders.Are ladder bars the same as traction or radius bars.Im reading alot about this and I still havent founf a straight answer.
