Those of you with B&W hitches and want outside frame airbags...... - Diesel Forum - TheDieselStop.com
Old 08-12-2009, 11:36 PM   #1 (permalink)
468LC's Avatar
I strongly suggest you try the Airlift 5000 series model 57291. This kit is specifically made to work with the B&W gooseneck hitch plates.
Get a more stable outside the frame stance which I needed anyways because of my exhaust. Installation was very straight forward but I did have to drill the two forward 3/8s inch holes. Had the install done in 3hrs by myself.
Now for my birthday I may ask for a dual control air pump system for it.
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 77k miles.
Wix/Baldwin coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT.
Mag-Hytec trans pan, 08 Diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
LineX, 20% tint, Weathertech liners.
2006 Forest River Sierra 5th wheel. 31' @ 11k pounds.
468LC is offline
Old 08-13-2009, 07:23 AM   #2 (permalink)
TxFireman1972's Avatar
Have any pics?
2005 F350 Crew Cab 4x4
PMF 08 Rear Leaf Spring Conversion
20" Harley Wheels w/275/65/20 Nitto Terra Grapplers
SCT X3 w/GearHead Tunes
Amp Research Steps, Bed Rug, Hellwig Rear Swaybar
Truck pic:
http://i210.photobucket.com/albums/b...bbd12e4e-1.jpg
"Two in the heart, and one in the head, I don't like repeat offenders, I like dead offenders!" -- Ted Nugent
TxFireman1972 is offline
Old 08-13-2009, 08:00 AM   #3 (permalink)
468LC's Avatar
Originally Posted by TxFireman1972 View Post
Have any pics?
Ask and you shall receive. I just got em loaded up or I would have posted last night. Sorry it's so dirty disclaimer lol. This truck is a user.
These pics are with 30 pounds in the bags already.
Steve
468LC is offline
Old 08-13-2009, 05:37 PM   #4 (permalink)
BadDogPSD's Avatar
Thanks for posting this! I was looking at these on-line yesterday and was considering starting a 'Ride Rite' or 'AirLift' thread. Looks like the Airlifts are less expensive and come with a lifetime warranty. How's the quality? Fit & Finish good? Relatively easy install?
1997 F250 4x4 Crew Cab PSD; Modded H2E, FFD Stage 2's, CPR Fuel, SRP1, ARP studs, Comp 910's, DI pushrods, Dana 60; Sky RSK w/SD springs.
BadDogPSD is offline
Old 08-13-2009, 09:57 PM   #5 (permalink)
468LC's Avatar
Well, I have installed both brands of kits over the years. In my opinion the fit and finish is fine on both. Both seam to have virtually the same design and build techniques. Both always seem to take a little fiddiling to get them perfect. It seems as though most people think firestones are better because of the name and they cost a little more but I am not so sure. I am not an advocate to either.
That being said I was just excited to find something that work with my hitch so I didn't have to drill 8+ holes through two hitch plates and the frame rails. That sucks and the drill bits get expensive.
Steve
468LC is offline
Old 08-23-2009, 03:41 PM   #6 (permalink)
Are you saying that the Firestones require 8+ holes to be drilled?
I thought they have a model that works with the B&W hitch similar to the Airlift.
I am also considering both brands for a purchase in the near future.
Thanks.
'01 F350 Dually 2wd 6sp/PTO option and AIC.
LUK clutch, AFE intake, 4" exhaust, DI 4pos custom chip with high flow injectors.
oneton is offline
Old 08-23-2009, 03:50 PM   #7 (permalink)
My brother got some firestones that required no drilling whatsoever. They work great with his b&w hitch.
Pat 2000 F250 Carpenter's Union local 2214
5" exhaust with 6"tip,foil delete,zoodad and 285/75/16 GT Adventuro
silverf00250 is offline
Old 08-23-2009, 04:11 PM   #8 (permalink)
468LC's Avatar
As mentioned in the begining of this fine thread, the Firestone no drills are inside the frame rails and won't work with my exhaust. I also hear they don't really fit with any aftermarket large diameter exhaust.
They are also IMO not quite as stable as outside the rail bags.
As I also mentioned you can use the outside the rails Ride Rites if that is the brand you insist on using. Just be prepared to drill a **** load of holes.
TIFWIW.
Steve
468LC is offline
Old 08-23-2009, 06:35 PM   #9 (permalink)
klhansen's Avatar
My Photos: (169)
It's only 8 holes for the Firestones that mount outside the frame rails. They're what I have, and the mounting looks stouter to me than the pics above with only 2 bolts per side. But that's just my opinion.
Drilling the holes was a bit of a workout, however. Be sure and use a good sharp bit.
Hard or no-start? Check Here
klhansen is offline
Old 08-23-2009, 08:19 PM   #10 (permalink)
TIFWIW.
Why won't it fit my brother has 5" exhaust and he didn't have a problem?
His exits in the stock location even with the spare tire under the truck there weren't any fitment problems.
Old 08-23-2009, 09:10 PM   #11 (permalink)
468LC's Avatar
At first I would have agreed. But after looking at it and the way these brackets are made to mary up to the B&W hitch plates the hitch acts as a gusset right over the airbag. It has two 3/4 inch bolts and one 1/2 inch bolt per side. I am not seeing anything flexing with this setup although if you wanted to take it to an engineering standpoint I would probably agree the 8 hole setup is better.
Also, like I said before, it's not just 8 holes through the frame rails but also through to thick ass hitch plates and the hitch plate doublers on the back side of the frame rails.
Don't get me wrong I am not trying to say the ride rites suck as I have owned them before. Just pointing out another option to people.
Steve
468LC is offline
Old 11-13-2009, 06:34 PM   #12 (permalink)
hey, awesome hook up on the pics, can you post some of the front of the moutn?
aminal_99 is offline
