Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 09-30-2008, 01:47 PM   #1 (permalink)
Thoughts about small lift & Tires
Hello All, I have a 2004 F-350 DRW CC 4x4 100% stock except for a shell and ARB front bumper. I use this truck to pull a 32' tag loaded to 12000 to 14000 lbs. My question is what is the general thought about adding a small lift and a little taller tire on the stock wheels? I meet a owner with a 99 that was pretty much the same truck with the 7.3 of course. He had what looked like 2" blocks added to the front and rear and had 255/85R16 on the stock wheels. He said that he used the truck to pull his flat bed tag loaded with his backhoe that was in the same weight range of what I'm pulling. I looked at the spacing between the rear tires and it looked OK? I asked if he had any problems with the rear tires rubbing each other when towing or loading the bed and he said no? What are the thoughts out there? Anyone ever use blocks (front and rear) to raise their truck and what about the tire size? Also what is the feeling on how this will affect my towing? Thanks for the help!
CZDiesel is offline
Old 09-30-2008, 03:43 PM   #2 (permalink)
i wouldn't put blocks in the front. i had an 04 DRW and i had add-a-leafs in the front and 4" blocks in the rear with air bags. i never had any issues with towing. i think 2" hangers in the front would give you a better ride than the add-a-leaf.
02 white CC LB SRW 7.3. Edge J/A, AFE Stage II, 4" straight exhaust, WW, billet TC, TransGo Tugger II, 203 therm, AIH delete, HX mod, engine boot kit, ZooDad, 2.5" front shackle, 2.5" front springs, SS brakelines, 5" rear block, rear airbags, ProComp traction bars, 37 12.5R17 ProComp X AT's on 17x8 ProComp 7089, painted door handles, billet grille, DEH-P650 Pioneer head unit, 400watt amp, 10" sub, 08 mirrors.
01 Yamaha Raptor 660 - the other money pit SOLD
vintage road bicycles - the new money pit
pictures
harmonjustin is offline
Old 10-01-2008, 02:17 AM   #3 (permalink)
Thanks HarmonJustin, I think that might be the common wisdom on the lift. But I have to tell you the blocks looked clean and the owner sweared they worked wonderful? Anyone with any experience with 255/85R16 on a dually that tows?
CZDiesel is offline
Old 10-01-2008, 11:06 AM   #4 (permalink)
Overkill's Avatar
My Photos: (31)
Front blocks are dangerous and illegal in most states. This is especially true when towing. The blocks will also kill your front springs quickly due to stress riser placed upon the leafs. Under braking the leverage effect of the increased distance from the axle to the springs bends the springs in an S shape and places a great deal of tension on the u-bolts causing eventual fatigue.
Marty G.
Truck Toyz Performance....Experience Matters!
TDS Sponsor
Authorized Dealer for One Up Offroad, Rize Ind., Icon Vehicle Dynamics, CST, RCD, BDS, Bilstein, King Shocks, Sway-a-way, Amp Research, Vision X, Fab Fours, and much more!
Visit us at:
www.TruckToyzPerformance.com & www.TruckToyzStore.com
Toll Free Ordering & Tech Support Line:
(888)776-8699
Overkill is offline
Old 10-04-2008, 04:51 AM   #5 (permalink)
Thanks for the knowledge Overkill. What are your thoughts on the mini spring packs?
CZDiesel is offline
Old 10-04-2008, 10:00 AM   #6 (permalink)
I would not use blocks either in the front. The front springs are weak anyways...I had a local shop take them off, re-arch them and add another leaf (full length) under the pack. The truck had 4" difference of height from front to back and now it has 2" (realizing it has the 4" blocks in the back). This was done to mine 5 or 6 years ago and I have not had any issues...I did remove the sway bar in the front to allow better articulation of the axle.
2000 F-350 4x4 CC srw - Tranny/Converter tricked, SCM, Walker BTM, K&N, front end picked up 2"
2000 Excursion Limited 4x2 - SCM, Banks muffler, K&N, nice stereo (400w for the wife), TV's/DVD (for the little ones)
2001 F-250 4x2 SC - SCM, Walker BTM, K&N
2001 F-550 6x4 RC - SCM, Walker BTM, K&N
1997 F-250 4x2 SC
bwguardian is offline
Old 10-06-2008, 12:04 PM   #7 (permalink)
Overkill's Avatar
My Photos: (31)
Icon Mini Spring packs are a safe alternative as they do not create a significant stress riser on the springs and do not place undue stress on the u-bolts.
Icon Vehicle Dynamics 2000-2004 FSD 2 Inch Mini Spring Pack Kit - 2000-2004 F250/F350 SRW 4wd - Truck Toyz Store
Marty G.
TDS Sponsor
Visit us at:
(888)776-8699
Overkill is offline
Old 10-07-2008, 06:45 AM   #8 (permalink)
Are you sure you need to raise the truck at all?
Beast is offline
Old 10-07-2008, 07:07 AM   #9 (permalink)
JimTJr's Avatar
My Photos: (6)
For that size tire, I doubt any lift would be needed. (Lifts also mess with fuel mileage,, something to think about)
Front BLOCKS a definite no-no....
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 10-07-2008, 05:16 PM   #10 (permalink)
I'm Sure your right Beast. I don't think that I need to raise the front to get LT255/85R16's under her. Its purely for looks. As for the mileage, won't the off set of having a slightly larger tire diameter have a bigger impact than a 2-1/2" frontend lift?
2004 F-350 4x4 CC DRW
Snug-Top Shell
ARB Front Bumper
CZDiesel is offline
Old 10-07-2008, 07:05 PM   #11 (permalink)
My Photos: (6)
You can clear those tires no problem. I cleared 295 75 16's on my stock ride height 01 DRW.
You you want a touch more lift in the front look into X springs off the F550 and you should gain around 1.5 inches
2001 F350 Dually, Crew Cab, 6x6, Lariat, 7.3 PSD
Auto, 4.10's, Camper Package
4.5" DR Edge Lift (soon to go on) Dual front shocks, 33" BFG AT's, 2" rear dually spacers, factory fresh trans
4" SS MBRP Cool Duals, Banks 1.0 Exhaust Housing, Banks Big Head, AIS Intake w/ Fender Cutout
DiPricol Optix Boost, Pyro, Full Sweep Trans Temp
My F350 DRW Pics
TalontedTSi is offline
Old 10-10-2008, 07:10 AM   #12 (permalink)
My bet is if you lift you will loose 1 mpg. Why not try the tires first and then see if you really want to lift?
Beast is offline
