time for new tires - Diesel Forum - TheDieselStop.com
Old 11-06-2009, 02:14 PM   #1 (permalink)
time for new tires
i have about 55,000 miles on the procomp xtreme at's...i don't think they will make it through another montana winter. i have no complaints with the tire and i am considering replacing with the same tire. anyone have a tire that they would recommend over the xtreme at...going with the 37 12.5R17.
02 white CC LB SRW 7.3. Edge J/A, AFE Stage II, 4" straight exhaust, WW, TM wastegate, billet TC, TransGo Tugger II, 203 therm, AIH delete, HX mod, engine boot kit, ZooDad, 2.5" front shackle, 2.5" front springs, SS brakelines, 5" rear block, rear airbags, ProComp traction bars, 37 12.5R17 ProComp X AT's on 17x9 ProComp 7089, painted door handles, billet grille, DEH-P650 Pioneer head unit, 400watt amp, 10" sub, 08 mirrors.
pictures
harmonjustin is offline
Old 11-06-2009, 06:55 PM   #2 (permalink)
Don't get that with my Nittos. Yet to see anything get me more then 45K or so.
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 11-07-2009, 06:53 AM   #3 (permalink)
fxdwgi's Avatar
I am also in the market for tires.....50k also on my tires (BFG All-KO) and I have been very happy with them. But I am looking at Dunlop Rover MTMaxx for the replacements, as they are E-rated and are FAR less expensive.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
