Tire size for factory 20s on a stock '06 350 - Diesel Forum - TheDieselStop.com
Old 10-24-2007, 01:43 PM   #1 (permalink)
I finally got my hands on a set of 20" Ford take offs and now I need tires. Truck is a stock '06 F350 CC Lariat with the camper pkg.
I'd like to run BFG AT 285/65R20s (34.7 X 11.5) but I don't know...
My 18" Contis are 32.1 X 10.9. Will I NEED a leveling kit to run a 34.7" tire? I never saw the 20" stock goodyears (close up)on another truck so I can't gauge how much I have to play with...
Thanks!
Pat
...A "Faceplant" is my most consistant wakeboarding "move"
'06 F-350 4X SRW LB Crew Lariat to pull an '04 Malibu VLX and a 10k dump trailer.
Make Welfare as hard to get as a Building Permit....
http://photos.thedieselstop.com/show...hp?photo=32801
Faceplant409 is offline
Old 10-24-2007, 03:18 PM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Re: Tire size for factory 20s on a stock '06 350
Those tires should work without any issues. The OEM tires were Goodyear AT/S LT275/65R20 if I remember right.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is online now
Old 10-24-2007, 07:30 PM   #3 (permalink)
Those tires should fit not a problem. The OEM tires are a 275/65R20. Myself I am running a 325/60R20 on the stock 20's with no rub, mind you I do have the front leveled. Those 285's will look good for sure.
2006 F350 Crew Cab Short Box
6.0L Powerstroke w/ 5 speed auto
Dark Stone/Arizona Biege
20" Stock Rims w/325/60R20 BFG AT's(winter)
17" Eagle Alloy 137 w/33" Nitto Mud Grapplers
Rev-Tek Leveling Kit / Bilstien 5100's
Spray in Box Liner, VentVisors
Chrome Nerf Bars
JBL 6x8 Speakers(Front and Back)
S&B Intake, EGR Cooler Delete
Muffler Delete with 5" S.S. Tip
Lost my cat somewhere
ABFord is offline
Old 10-25-2007, 03:39 AM   #4 (permalink)
Did the 20" wheel tricks come with lower gears???
Old 10-25-2007, 11:43 PM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Faceplant409</div><div class="ubbcode-body">Did the 20" wheel tricks come with lower gears??? </div></div>Nope, only gears for a diesel truck were 3.73 no matter what tire size was on it.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
Old 10-25-2007, 11:58 PM   #6 (permalink)
dieselwhisperer's Avatar
While we're on this subject, I also have got a set of 20" take offs coming for my 08 F250. My truck has the cheap-o chrome 17" wheels on it right now. Here's my question, I know my speedo is going to be off but how much and in which direction? The way I'm thinking, the larger tire will travel more distance per revolution than the smaller tire, so will I be actually going faster that my speedo says or slower? Also, you would think that the miles on the odometer would show less miles than you actually go.
2008 F250 Crew long bed XLT 6.4 diesel, automatic, White.
dieselwhisperer is offline
Old 10-26-2007, 02:36 AM   #7 (permalink)
I think the miles would be recorded incorrectly. From what I have gathered...... the stock tires on the Goodyears were like 601 revs/mile. The 18" contis were 653 rpm and the BFG 285/65/20s are 599 rpm. Apparently the dealer can only adjust to the largest tire offered from the factory (20" Goodyears @ 601 r.p.mile. So the speedo can be close if you have the dealer do it.... but not spot on.
There are other ways of adjusting, I'm just not interested in them.
Patrick
