Torque Values for Front End - Diesel Forum - TheDieselStop.com
Old 12-28-2005, 10:29 AM   #1 (permalink)
Does anyone have the torque values for the front end (springs, shackles, brackets, etc)? I've torn the front end apart to put a lift in and can't seem to find the values anywhere. I thought I had remembered seeing the values posted from the Ford service manual, but have been unable to find them. If anybody has them and is willing to post them, it would be a great help. Thanks in advance for the help.
2005 F-350 Crew Cab,6.0L,Auto,4x4,King Ranch,White and Arizona Beige,Edge Evolution, MBRP 4" exhaust, 2.5" Donahoe Racing leveling kit,LT305/70-18 Dick Cepek Mud Countrys,Pro Flaps,Husky Liners,Draw Tite gooseneck hitch.
Sold: 2000 F-250,4x4,SC,XLT,Island Blue,Auto, Autometer Z-series Pyro, Tranny, and Boost gauges,
AFE Magnum Intake with Pro-Guard 7,TS 4-position (stock-50-75-140) Flip Chip,DPPI 4" exhaust w/ 3.5" downpipe,Sonnax/Tricumulator springs mod, TruCool Max,Edge 3" leveling kit w/4" blocks,16.5x9.75 Weld Typhoons,35x12.50x16.5 BFG A/T, Westin chrome nerf bars,Pro Flaps,B & W Turnover Ball,Husky Liners.
pwrstroker00 is offline
Old 12-28-2005, 12:26 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Re: Torque Values for Front End
<font class="small">Code:</font><hr /><pre>
Torque Specifications
Description Nm lb-ft
Adjusting Sleeve Clamp Nuts — F-250, F-350, F-450, F-550 55 41
Front Spring U-Bolt Nut — F-250, F-350, 4x4
and F-450, F-550 133 99
Lower Ball Joint Nut — F-250, F-350, 4x4 and F-450, F-550 º º
Rear Spring U-Bolt Nut — F-250, F-350 250 185
Rear Spring U-Bolt Nut — F-450 300 222
Rear Spring U-Bolt Nut — F-550 350 259
Upper Ball Joint Pinch Bolt — F-250 and F-350, 4x2 80 60
Upper Ball Joint Nut — F-250, F-350, 4x4 and F-450, F-550 125 93
1/4-Inch Diameter Bolts and Nuts — Grade 5 12 9
5/16-Inch Diameter Bolts and Nuts — Grade 5 20 15
3/8-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8 50 37
7/16-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8 82 61
1/2-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8 122 90
9/16-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8 176 130
5/8-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8 240 178
3/4-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8 350 259
7/8-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8 570 420
1-Inch Diameter Bolts, U-Bolts and Nuts — Grade 5 860 634
º = Refer to the procedure in (the workshop manual)
</pre><hr />
SmokeyWren is offline
