Towing Mirror Upgrade - Diesel Forum - TheDieselStop.com
Old 11-10-2009, 05:27 AM   #1 (permalink)
5Rvers's Avatar
My Photos: (10)
Question Towing Mirror Upgrade
I have a 2000 F450 7.3 PSD and I would like to upgrade my towing mirrors with an 03-07 power signal mirrors. Is this doable without major modifications and if I can what is required? I'm assuming new wire harness is required. Appreciate any information.
Thanks in Advance,
Lou
2000 F450 7.3 PSD CC DRW
ISSPRO Gauges
50 Gallon Transfer Flow Tank
Firestone Ride-Rite Air Bags
2005-07 Front clip change
Ford Severe Duty AIS
DP-Tuner
Diamond Eye 4" Turbo Back Exhaust
5Rvers is offline
Old 11-10-2009, 10:05 AM   #2 (permalink)
Lou,
My 02 had the paddle mirrors when I got it. I wired up the signals to the main harness under the dash but I can't recall what colors. I wired the heated elements to the hot side of the power window switch feeds. I didn't need any new wiring harnesses as I cut/soldered where I needed it.
I can't find the original article I used, but this one is close:
New Mirror installation
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, 6.0 Trans cooler, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
2008 H+H 24' CL series V Nose Car Hauler
Blk88GT is offline
Old 11-11-2009, 09:56 AM   #3 (permalink)
5Rvers's Avatar
My Photos: (10)
Thanks Blk88GT for the installation link. I just order the Kool Vue mirrors with the heated and in-housing signal light from Auto Parts Warehouse.com. Can't wait to get them installed.
Lou
ISSPRO Gauges
DP-Tuner
5Rvers is offline
Old 11-11-2009, 08:15 PM   #4 (permalink)
dgribble's Avatar
I have 06 mirrors on my 01. I haven't hooked them up yet but I've been looking at the Muth Miror system. Muth Mirror Systems, LLC
2001 F250 7.3 4x2 4R100(Performance)-Garrett GTP38R 4.0" turbo back Polished stainless exhaust K&N aircleaner tube w/Amsoil air cleaner-Snow Methanol Stage3 6ltr intercooler-Big Dawg tranny cooler W/E-Fan-air ride rear-Heat extractor hood-4:10 rear gear-08 diff cover-Isspro ev gauges Volts-Tranny Temp-Water Temp-Fuel Pressure-
Polished and Red CFM+-Airdog100-Jobes EBV delete
Stealth Dual HPOP w/custom made fittings-
Edelbrock AIS shocks CCV Mod-Amsoil bypass filter
Diesel Innovations fuel return system
Swamps 275 Injectors-Flexi-A-Lite E-Fans
09 Cyclone 40ft Toy Hauler
08 Harley FXCWC
dgribble is offline
Old 11-12-2009, 11:30 AM   #5 (permalink)
Lou
Lou, are you interested in selling your old mirrors?
4x4Given is offline
Old 11-12-2009, 03:25 PM   #6 (permalink)
I just put '08 mirrors on mine. If you ever use them you'll never want the others.
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 60000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 185,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline
Old 11-13-2009, 09:31 PM   #7 (permalink)
5Rvers's Avatar
My Photos: (10)
I think I will keep them for now. If I do decide to sell them I will let you know.
Lou
ISSPRO Gauges
DP-Tuner
5Rvers is offline
Old 11-19-2009, 02:26 PM   #8 (permalink)
Do you have any information how to install the '08 mirrors? Do they fit up properly? Any info on the wiring? Interested to install on my '99.
1999.5 F350 DRW Crew 4x4 7.3L 6-Spd XLT Flatbed 4.10L 347k. ??12 gears - can't one be for highways / expressways??
Sold -1999.5 F350 SRW Crew LB XLT 4x4 7.3L 6-spd 3.73L 355k -
Sold - 2005 F350 SRW Crew LB Lariat Fx4 3.73L 6L Auto almost all options
tequila0 is offline
Old 11-19-2009, 03:38 PM   #9 (permalink)
Installed them on my '99. Just need to wire the turnsignals.
D/S mirror: RD-right/left movement, YE-motor feed, DB- up/down movement, LG/WH-turn signal, BK-defrost,turn signal ground, DG/VT-switched defrost, BN-parking lamp...
P/S mirror: DG-right/left movement, YE-motor feed, VT-up/down movement, WH/LB-turn signal, BK-defrost,turn signal ground, DG/VT-switched defrost, BN-parking lamp..
EBPV Deleted
Banks Tubes
Terminator
2002 JCB 212s
2004 A300 Bobcat
Old 11-23-2009, 11:05 PM   #10 (permalink)
I am upgrading mine (07) heated, power manual extend and fold to the 09 power everything. I have them mounted and wired but need harness 14A413? Does anyone know where an 08-10 is in a junk yard?
Rick1067 is offline
