TOYO MT AIR PRESSURE - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 10-24-2006, 11:48 AM Thread Starter
I just purchased Toyo 35x12/50x20 MTs. The max load pressure for them is 65psi max. The max load pressure for the stock tires is 85psi. The standard pressure in the door for the stock tires is 65 psi. The toyos sure are stiff at that pressure. What are you guys running for pressure for every day driving? I can air them up when loaded.
PC20 is offline
post #2 of 12 (permalink) Old 10-24-2006, 12:36 PM
LiftedBlackHD's Avatar
Re: TOYO MT AIR PRESSURE
I'm running 60psi in mine. The ride is definitely stiffer but I dont want to go adjust my tire pressure every weekend when I tow my boat. With the higher air pressure I get about 1 mpg better per gallon, and it makes steerring at idle much easier.
2004 F250 Super-Cab Long-Bed 6 Liter PSD 4x4 Harley Davidson Edition
SCT tuned by DJ
8" Icon Suspension System
Fab-Tech dual steering stabilizer Kit
20" KMC Rockstars (Black)
38" Toyo Open Country's M/T's
Zoodad mod
CCV mod
High-idle mod
Straight Piped
Outlook Monitor
Recon Led's
Innovative Diesel 05-07 Intake Elbow
Dieselsite Coolant Filtration System
Southern California PowerStrokes Member
LiftedBlackHD is offline
post #3 of 12 (permalink) Old 10-24-2006, 02:51 PM
CSIPSD's Avatar
My Photos: (52)
I ran mine at 55 for the life of them... 55,000 miles...best towing tire out there if you ask me...
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #4 of 12 (permalink) Old 10-24-2006, 02:54 PM Thread Starter
Thanks guys,
I had settled on 55 in the front and 50 in the rear. I just did not want to wear them out to fast.
PC20 is offline
post #5 of 12 (permalink) Old 10-24-2006, 03:39 PM
That's a pretty strong statement. Really? I have been looking at them but was woried about towing and wearing them out quickly. Hmmmmm...
2000 F350 7.3L CC/LB 4X4 XLT/6-speed/DP-Tuner/Bean's 1.0 with WW/4" turbo-back exhaust/AIS/Isspro EV's/285-75-16 Goodyear Wrangler PRO-GRADE/LS monotube shocks/Prodigy trailer brake controller/zoodad/leveling kit/All red - what other color would a firefighter have?
2002 F250 7.3L CC/LB 4X4 Lariat/4R100/DP-Tuner/Bean's Van Turbo with WW/Isspro EV's/4 inch lift/285-75-16 Goodyear Wrangler PRO-GRADE/LS monotube shocks/AIS/4" turbo-back exhaust/zoodad/ALL Black - wife's truck
Just because you can, doesn't mean you should!
FireHunter is offline
post #6 of 12 (permalink) Old 10-25-2006, 10:05 AM
SmokeyWren's Avatar
My Photos: (45)
The tire industry strongly suggests you pump the tires up only to the PSI needed to support the load you are hauling on that tire. So use a load/inflation table, along with a weight ticket that shows the weight on each axle, and apply that table.
All tires that have a weight capacity of 3,195 pounds @ 65 PSI will have the same load inflation table. Here it is for your tires:
PSI Load
35 2040
40 2245
45 2440
50 2680
55 2805
60 2980
65 3195
When unloaded, your weight ticket might show 4300 on the front axle and 3500 on the rear axle. Which is 2150 on each front tire and 1750 on each rear tire. So per the above load/inflation table, you'd need 40 front and 35 rear when unloaded.
Put the truck to work, and you might have 4600 on the front axle and 5200 on the rear axle. Or 2300 on each front tire and 2600 on each rear tire. So in that case the above table says 45 front and 50 rear.
Loaded to the gills and right up against the weight capacity of your tires, then you might have 5,000 on the front axle and 6300 on the rear axle. Or 2,500 on each front tire and 3150 on each rear tire. That means you'd need 50 in the front tires and 65 in the rear tires.
Note that with only 3,195 weight capacity per tire, an '05-up F-350 SRW no longer has a GVWR of 11,500 pounds. With a max load of 6,390 on the rear axle, a GVW of 11,500 would probably overload your rear tires.
SmokeyWren is offline
post #7 of 12 (permalink) Old 10-27-2006, 02:45 AM
Woah, maybe I'm under-inflated then. I'm running 35psi in my 37x13.5x17 MT's. If the above chart is right, that should still work for a 8160 load. They are load range E. For my truck, and also pulling a 5000lb trailer- what should I be running? Maybe I shoudl take it up to 45psi.
I know you have to be careful with pressures- my dad had a '89 E250 diesel van, put on Michelin 10 ply truck tires and pumped them up to the max (I think 85psi). Took a bumpy interchange ramp and just about bounced off the road into the barriers. He found out that he only needed half that pressure.
2012 VW Touareg TDI
2008 4runner
sold- 2003 F250 4x4 diesel
Looking for another....
zimm is offline
post #8 of 12 (permalink) Old 10-27-2006, 12:00 PM
[/ QUOTE ] The above numbers do not apply to your 37 MTs. At 65 psi your max load is 4300lbs.
toalpi is offline
post #9 of 12 (permalink) Old 10-27-2006, 12:12 PM
MDarrough's Avatar
My Photos: (18)
I run 45 front, 35 back in my 38s.
Mark
2011 F-350 DRW 4X4 Lariat -
Pulling a 2010 Sierra 355QBQ 5er
Sold- '08 F-350 -
Sold - '01 F-350 -
MDarrough is offline
post #10 of 12 (permalink) Old 10-28-2006, 09:21 PM
DCSpecial's Avatar
My Photos: (21)
On my 38/14.50R16s I'm running 42psi front and 32psi rear.
Seems to be the best psi to get them to ride and wear well.
DCSpecial is offline
post #11 of 12 (permalink) Old 10-30-2006, 09:15 PM
with tires in sig. 50 front & rear, more in rear's depending on load
E '99, F-350SRW, CC, LB, 4x4, 6-spd,DI Prods, South Bend DD, HX55, 238/200's,ARP HS, Comp 910's CCV, Reg. Return, 5/8" Intank
JHill is offline
post #12 of 12 (permalink) Old 11-01-2006, 09:45 PM
I run 47 up front and 42 out back when unloaded and have gotten even wear and consistent chalk marks running 37x13.5R17 Toyo MTs
2003 F-350 6.0L Fx4. AFE, DPPI turbo back. Supercab, LWB
6" Front Deaver Springs
8" Rear Deaver Springs
37x13.5R17 Toyo MT on 17X10 Eagle 114
4.56 gears, Detroit Locker in Rear, ARB up front
VIAR 550C, two 5-gallon tanks under bed, inverter, 6A on-board battery charger, coolant filter, quick disconnect jumper cables, Zoodad mod, bumper spaced 1", rear shock mounts rotated, too much more to mention.
8400 lbs empty weight
nuctrooper is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
