Re: Trackbar vs. Bo xkit what do I need?
Definently need to address the track bar and relocation geometry...I would suggest an-adjustable one and a dropped bracket...I used the one that is threaded and adjusts like a tie rod...
Good luck on getting 2 inches on the X-springs...but they will roughen the ride!
Dropped pitman arm would be good and stabilizer link ends as well..cheap insurance...thats not a bad price on the leafs, if that is both...dont forget the u-bolts as well..
Good luck..
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
