Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 09-25-2008, 02:58 AM   #31 (permalink)
josea1952's Avatar
What is this factory stabilizer you guys speak of? I put the full traction kit on my truck with no stabilizers and I have zero probs. I also lifted a friends truck and with atlas leafs and that thing was everywhere until we put on the steering stabilizer. Tires were definitely taking over.
josea1952 is offline
Old 09-25-2008, 03:05 AM   #32 (permalink)
soflasmoker's Avatar
I have the same problem but i have no steering stab not even stock im going to tighten my gear box becuz i have bad play due to the roads tht i drive down and the big tires tearin everything up but i was also told that it could be my trac bar which is supposed to stop axle wrap (the axle moving left fwd right fwd and vice versa) and it is supposed to be torqued to 400lbs and i havent been able to tighten it but people say i prob have bad bushings my truck is torn apart now for oil cooler fix so im gunna tighten my gear box and see about the bushings and ill let you know if it fixes it mine not only does it over certain bumps but also if i try to come to a stop too fast it scares the hell outta ya.. ill update you soon my truck should be done fri tht is if my cooler gets here.
00 f250 xlt crew cab 4x4 7.3 psd
sct programmer, 4in bully dog turbo back exhaust, 6in suspension lift with 35in terra grapplers on 18in 05 king ranch rims SOLD!!!
05 F250 Lariat Crew Cab 4x4 6.0, SCT Xcal2 with custom tunes from Direct Injection Performance, 6in MBRP turbo back aluminized exhaust w.5in tip, AIRAID air intake, 4in fabtech suspension lift, 36in nittos, 20in blak & chrome ULTRA rims, 2 jbl 12s, 600watt kenwood amp and kenwood ddx-712 double din head unit, HID,s that everybody hates cuz theyr so blinding lol
soflasmoker is offline
Old 09-25-2008, 01:54 PM   #33 (permalink)
Banned
that would be great!!
BADASS03SVT is offline
Old 10-07-2008, 11:21 AM   #34 (permalink)
stevedunham's Avatar
Didn't read all the responses so not sure if this was mentioned but you can also get a "death wobble" if your Trac Bar is loose or if the Trac Bar Drop Bracket on the frame has worked itself loose... These need to be TIGHT and I mean TIGHT, especially the lower Trac Bar NUT/BOLT where it mounts to the axle on the passenger side... I have 2 lifted Fords with Dana 60 front axles, each of which has a Trac Bar and each has had an issue with the Trac Bar working itself loose... I torqued all nuts/bolts to spec and used Green Locktight Thread Lock and they seem to be behaving lately... Just another thought...
** SMD '04 F250 SD King Ranch delivered 8/19/04 LOOKS BETTER THAN SHE RUNS! **
28% Tint, Leer 100XL Cap, DR Edge 7" hybrid lift w/ 5" rear leafs, 37x13.5x17 Toyo MT's, Draw-Tite portable winch mount, WARN xD9000i, MBRP Duals, 4.56's w/ F&R ARB's, original motor blown @ 31,000..! Dynatrac Free Spin Dana 60 35 spline stubs kit, PIAA 520 ATPs, PICS
stevedunham is offline
Old 10-07-2008, 08:22 PM   #35 (permalink)
no steering stabilizer
i had the same problem with my truck. you need to get the caster and camber adjusted in your front end it will straighin the problem right out.
05 f250 psd, Edge products, 4 inch MBRP stright out, AEM brute force intake, 8" procomp lift with 37" m/t, 18" diamo wheels
StrokerMoe is offline
Old 10-09-2008, 01:21 PM   #36 (permalink)
Death Wobble happens when your track bar is loose or has broken bolts too...I know.
Anthony P is offline
