Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 11-04-2008, 12:17 PM   #1 (permalink)
Unloaded PSI in new tires?
I upgraded to the E rated BGR AT/KO that is an 80psi max tire. I run the 80psi when I'm fully loaded, but what should I be running the tire at when unloaded?
The truck weighs 8,000 lbs full of fuel with just me in it.
Right now I'm running them at 70 psi in the front and 66 psi in the rear. Does that sound right?
I got the tire inflation chart from BFG, but it makes no sense to me.
2002 F-350 XLT 4X4, 7.3 PSD, CC, LWB, SRW 4 Speed Auto, 3.73 Limited Slip, Rancho 9000 Shocks, M/T® Classic II®, 285 75R16 BFG AT T/A, WAAG Wheel-to-Wheel Tube Steps, Reverse Lights, Upgraded Headlight harness with Silver Stars, ISSPRO EV EGT & Boost Guages, Ford AIS with Fender Intake Mod, MBRP 4" SS Exhaust
My truck
ewinghr is offline
Old 11-04-2008, 12:25 PM   #2 (permalink)
JW350's Avatar
My Photos: (29)
The tire inflation chart shows you the minimum pressure for a given load. If you have the weight of both your font and rear axles, use those to find the appropriate tire pressure on the chart for the front and rear wheels.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, 37x13.5x17 Tires, 4.88 Gears, Turbo-back Exhaust, Gauges, Air Bags...
JW350 is offline
Old 11-04-2008, 01:28 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (42)
No, it sounds like you're way overinflated for unloaded cruising when grossing 8,000 pounds. 70 PSI in the front tires is enough to support about 7,000 pounds on the front axle. Your front axle GAWR is only 5,200 pounds, so I hope you never have over 5,200 pounds on the front axle. For 5,200 pounds front axle weight, the most you'd need in those big tires is 50 PSI.
66 PSI in the rear tires is enough to support over 6,600 pounds on the rear axle. If you have 6,600 pounds on the rear axle, you're going to have a GVW of over 11,000 pounds, or more than a thousand pounds over the GVWR of your truck.
Load/inflation table for LT285/75R16
PSI Max weight
35 2,130
40 2,340
45 2,540
50 2,755
55 2,925
60 3,110
65 3,305
70 *
75 *
80 *
* = you'll never need that much PSI unless you're severly overloaded. That's why a load range D tire is all you need in size LT285/75R16.
Weigh the truck on a CAT scale to get the weight on each axle. Then divide that axle weight by two to get the approximate weight on each tire. Then apply the above chart.
For example, if your front axle weighs 4,500 and your rear axle weighs 3,500 for a GVW of 8,000 pounds, that's 2,450 pounds on each front tire and 1,750 on each rear tire. The chart above says you need at least 45 PSI to handle 2,450 pounds, and you need at least 35 PSI to handle 1,750. So you would be perfectly safe with 45 front and 35 rear. But if you'd feel more comfortable with a bit more fudge factor, then maybe run then at 50 front and 40 rear when unloaded.
When loaded for bear with a GVW of 10,000 pounds, you'll probably have a front axle weight of less than 5,000 pounds and a rear axle weight of less than 6,000 pounds. So that would be a max of 2,500 pounds on each front tire and 3,000 pounds on each rear tire. For that load, the chart above says you need at least 45 PSI in the front and 55 in each rear tire. So up one notch as a fudge factor, and run 50 front and 60 rear.
IOW, unless you're severely overloaded, you should never need more than 50 front and 60 rear - as long as you have those big tires. Smaller tires have a different load/inflation table. And bigger tires have a different load/inflation table too. So use the correct load/inflation table for your size tires.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is offline
Old 11-14-2008, 06:28 PM   #4 (permalink)
I run all 4 at 80 psi when I have the truck camper loaded and towing the boat. It just feels more stable and I don't rock side to side down the highway.
I had the Load D range in the same tire and those didn't feel good fully loaded and they wore really fast.
I bet a run a bit over gvw when fully loaded so that might be the reason why.
Am I more at risk of a blowout running over inflated or under inflated?
My truck
ewinghr is offline
Old 11-14-2008, 09:11 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (42)
Underinflated for the load can cause a blowout in a heartbeat. By overinflated, if you mean for the load, then the only things bad are the harshess of the ride and the tires will wear out faster in the center of the tread.
If by overinflated you mean over 80 PSI cold, then simply don't do dat.
Old 11-14-2008, 09:29 PM   #6 (permalink)
chris u's Avatar
I run my tires at 47 lbs. during the winter when not towing just less pressure more traction. Run at 65 in the front and 80 in the rear when towing. Just what I do doesn't mean it's right but seams to work.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline
Old 11-15-2008, 05:28 PM   #7 (permalink)
Blue Water Runner's Avatar
Unloaded I run 55 up front and 60 in the rear. Loaded with the truck camper and boat I run 70 up front and 80 out back.
Visit me on Facebook
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Straight Pipe,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer
My Pictures
Motorcraft Filter Comparison Video
Fuel Quality Video
Blue Water Runner is online now
Old 11-16-2008, 06:41 AM   #8 (permalink)
When I first bought my new to me 03 I inflated the tires to 65. Ride is pretty harsh on the small bumps. I am sort of curious how much difference there is in MPG from 45 to 65 without going through all the hand calculations again. Are we talking 1 or .1 mpg?
2003 7.3 F250 SD SRW Auto DIY intake 285/70 1.5" Leveling Kit TS Performance 75 HP Chip
TTBadDog is offline
