Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 10-09-2008, 04:35 AM   #1 (permalink)
Viair 380c compressor problem...
Hey guys,
It's been a long time since I've been on here, glad to see most of you still around. My viair 380c went out on me about a week ago, it still pumps air but it is leaking out through the air filter so I can't keep any pressure in the tank. Anyone know what is causing this? Is there somewhere that sells parts for these compressors? I tried google but can't find anything. Appreciate the help!
Ikaika
'05 Black F350 CC FX4 Lariat, Fabtech 8" 4-link lift, 20x10 Diamo 16 karat w/ 37x13.5 20 Toyo open country m/t's, X-monitor gauges, Quadzilla 120
ikaroback is offline
Old 10-09-2008, 09:55 AM   #2 (permalink)
Send a message via ICQ to kcastle
If it is anything like other compressors I have worked on, it is leaking out the reed. Could be a loose screw or pin hole in the reed.
My Truck
2000 F250 Crew Cab 7.3L Diesel, BTS Tranny, AFE intake, AIT heater delete, EBV delete, Wicked Wheel, 4 position chip from BTS, Walker BTM muffler, In tank and pre-pump mods, Custom polished skid plates and air tank, 37 Toyo Mud Terrains
kcastle is offline
Old 10-09-2008, 10:17 AM   #3 (permalink)
These guys have about everything. I am replacing my plastic air filter assembly with the metal one.
Poly Performance Inc.*::*Onboard Air Systems*::*VIAIR Parts & Accessories - JK Synergy Suspension Systems, Fox Racing Shox, Beard, CTM, Johnny Joints®, Currie Enterprises, Edelbrock, Total Chaos, Ramsey Winch, Walker Evans, Wilwood, Mastercraft, CNC
Barrett
Mine: 2003.25 F-350 Lariat CC, SRW,8' bed, 6.0, Torqshift, Toreador Red, Tan Leather, Trailer Tow, Rhino-Liner, Dee-Zee Platinum Box, Adjustable Pedals, Heated Seats, 6 Disk Changer, DVD, 04 Keypad, AIC, 20% Tint, Escort 8500 X-50, Magellan Meridian Color Gps, Goodyear Wrangler 285 MTR’s. DPPI Dual SS Turbo Back Exhaust,"X" Springs,Issopro EV Pyro,Trans,Boost Guages, Under Dash Pod, Viair 550C AC, 26" & 29" Hadleys, 2006 Front End, Chrome Tow Hooks, Warn 16.5ti, Billet Cummins Killer Badges, Int. VT-365 Badges.
Diesel_Mom's: (Redhead): Goodbye 2001 EX, Thanks for 4 years. Brand Spanky New 2005 Eddie Bauer Excursion, DVD, Toreador Red</font> , 6.0L Powerstroke, all options including (3) children, (1) 95# Golden Retriever, Goodyear Wrangler 285 MTRs.
babacraig is offline
Old 10-09-2008, 11:52 AM   #4 (permalink)
My 450c has a slow leak so I put a check valve between the tank and pump. Cheaper than replacing the pump. Let us know if the filter works for you. I also put one between my airbags and the tank so if I loose air the bags will stay full.
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, whicked wheel, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
Old 10-09-2008, 02:52 PM   #5 (permalink)
Thanks guys! I think I'll go with the check valve idea that boathauler mentioned. Money is a little tight right now. I can't seem to find any replacement parts other than filters, relays, pressure switches etc..etc... Anyone know if these compressors are rebuildable? or do we need to buy a new comp. when they go kaput!!
Thanks again
Ikaika
Old 10-09-2008, 03:03 PM   #6 (permalink)
Thanks again
Ikaika
My understanding is that they are completly rebuildable. Although I have never tried or looked for parts for one. Try calling them, they may have a kit you can purchase that would have all the wear parts to replace.
I found a link, so they are out there.
KP Components :: Compressors :: Compressor Parts :: 380C Compressor Connecting Rod And Piston Rebuild Kit
Old 10-09-2008, 04:11 PM   #7 (permalink)
there is a braided steel line that has a check valve built into it sells for like $10 IIRC try suicide doors . com
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
truckosaurus
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline
Old 10-09-2008, 06:12 PM   #8 (permalink)
Damn, thats a good deal. I spoke to viair and they are rebuildable, they told me to take it apart to see what part went bad. I did that and found one of the valves (about as big as your thumb nail except it's about 1 inch long and paper thin) to be warped. I ordered 2 of them thinking it would cost a couple bucks apiece!!!?? Ha, $20 each!!! Can you believe that crap! I think I'll call them back and cancel that order and go with the braided hose w/check valve.
Old 10-10-2008, 10:58 AM   #9 (permalink)
I prefer the check valve anyway. That was if something does go wrong it keeps pressure in the system
Old 10-10-2008, 02:58 PM   #10 (permalink)
Yeah, I cancelled the order for the valves and got the leader hose with built in check valve.
