What is a good brand of brake fluid for my superduty and what quantity? - Diesel Forum - TheDieselStop.com
Old 07-30-2006, 08:07 PM   #1 (permalink)
My Photos: (5)
I thought there was a fluid that many people were switching to. I need to do my car, which requires dot 4 and the truck which is dot 3. Any suggestions? Thanks
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 100,500 miles. truck Pictures
clydesdale is offline   Reply With Quote
Old 07-30-2006, 08:17 PM   #2 (permalink)
Re: What is a good brand of brake fluid for my superduty and what quantity?
This is good fluid that isn't overpriced. It will work in both vehicles.
444-4D is offline   Reply With Quote
Old 07-30-2006, 09:09 PM   #3 (permalink)
My Photos: (14)
I have used the Valvoline SynPower Brake fluid. Exceeds DOT 3 and 4 specs. Doesn't spec quite as high as the fluid linked above (The valvoline is 480F Dry and Minimum 330F Wet) But Its available locally for a little less than half the money, about 5 and change a quart IIRC.Since either fluid is going to absorb moistureand slowly degrade the performance, you can change the valvoline almost twice as often for the same money. I try to shoot for every two years.
In terms of how much fluid a quart for each should do it. Suck as much as you can out of the master cylinder reservoir. On My Ford I pulled the the little foam float out to get a tube in there for the mighty vac. almost got it empty. Fill with fresh and bleed till its clear. I usually go around twice and burn a little extra fluid to make sure I got all the old stuff out. With a mighty vac you can bleed solo.
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline   Reply With Quote
Old 07-30-2006, 09:37 PM   #4 (permalink)
468LC's Avatar
When I flushed my 99 it took almost 2.5 quarts to get the fluid to go clear at all 4 corners.
I used castrol. I don't really think it matters what brand so long as the spec is right.
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 77k miles.
Wix/Baldwin coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT.
Mag-Hytec trans pan, 08 Diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
LineX, 20% tint, Weathertech liners.
2006 Forest River Sierra 5th wheel. 31' @ 11k pounds.
468LC is offline   Reply With Quote
Old 07-31-2006, 01:16 AM   #5 (permalink)
artherd's Avatar
I second the recomendation for the ATE SUPER BLUE/TYP200.
"Racers frequently will alternate fluid flushes using both the SuperBlue and TYP 200 (Amber). The identical specifications of the fluid and difference in color makes it easy to know when you have completely flushed old fluid out of the system."
This works fabalously by the way. Reason enough to order a case of each. I use about 2 qts per flush with my 350.
- 99 F350 CC, LB, Dually - 01/98 Production Date - Tommy Gate hydraulic liftgate (awesome & highly recommended.)
- 19.5" Goodyear G622s on F550 wheels front and rear.
- F550 brakes. 1050CFM thermostatic 2nd tranny cooler. Prodigy brake controller.
- 4" exhaust to the turbo. 4-pillar EGT, TRANS, WATER, BOOST.
- Ford Ambulance APCM/AIC. Severe Duty AIS.
- Code 3 2100 LED Lightbar, Perimiter Strobes, LED-X lights, Electric (firetruck type) warning horn & PA.
- 4 batteries, Xantrex 250A automatic battery combiner/splitter.
- Dual Xantrex Prosine 2.0KW inverters for 110/220v, Laser printer/copier, plasma cutter, welder.
artherd is offline   Reply With Quote
Old 07-31-2006, 07:07 AM   #6 (permalink)
I've used both Valvoline SynPower and ATE SuperBlue/Type 200 in my racecar and street vehicles. They are both excellent fluids. Also, Ford makes a very good brake fluid - Ford HD. Though not as robust now as it used to be, it is still a good product.
I will use Valvoline when I flush the fluid in our 2004 PSD, mainly because of availability and cost. Plus, I don't have to worry about boiling fluid while late-braking into the hairpin at Sebring when I'm driving the truck [img]/ubbthreads/images/graemlins/wink.gif[/img].
Joshua
CoralDoc is offline   Reply With Quote
Old 07-31-2006, 07:39 AM   #7 (permalink)
NCHornet's Avatar
I also used the Valvoline and it took 3 quarts for a complete flush.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline   Reply With Quote
Old 08-06-2006, 08:35 PM   #8 (permalink)
My Photos: (5)
I used the superblue racing fluid and my motive product power bleeder for the first time and they seem like a beautiful combo. I also bought the amber fluid for the next flush. This way I can switch colors and easily know when new fluid is in. I bought it from bavarian auto www.bavauto.com It is a bmw site but they will match all prices and they matched the 9.95 a bottle price without having to buy a case. So if you want to save 2 bucks a bottle on smaller quantities, try bavarian. Thanks for the help.
Old 08-06-2006, 09:37 PM   #9 (permalink)
Pappy19's Avatar
My Photos: (6)
http://www.bestbrakes.com/ate_brake_fluid.shtml
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline   Reply With Quote
