Where to connect power wire for sat radio (hardwire) - Diesel Forum - TheDieselStop.com
Old 12-26-2005, 07:13 PM   #1 (permalink)
DecreasingDave's Avatar
Hey guys,
I got Sirius for X-mas and ran the antenae, made a custom mounting bracket and I'm all set to go 'cept for the power wire.
It comes with the power port plug but I want to hardwire it. It apparently is not capable of turning on and off with the radio so I just need to find a permanent power wire that's easy to get to.
Any help will be appreciated.
Dave
2003 F-250, 4x4, CC, SB, 6.0 PSD w/Torqshift, Lariat, Toreadore Red/Arizona Beige
- Airaid intake
- MBRP Turbo-Back Exhaust
- Cross Over Fuel Line and 1/2 Banjo Bolt Mod
- Quadzilla Commander
- Zoodad Mod.
- Doorseal Mod.
- X-Springs and F-350 Blocks
- Full Traction 4.5" Hanger lift
- ProComp Add-A-Leaf and Velvet-Ride shackles
- BFG 35" All Terrains on Ultra Predator 17x10s (Hub-centric)
- Centramatics
- Timbrens
- Extang R/T Tonneau Cover
- EZ Down Tailgate Strut
- C.R. Laurence PowerSlider Rear Window
- Sirius Sat. Radio
- Polk Ex3 5x7s and 2 JL Audio 10w0s
driven by a 6 channel amp
- SCT from Innovative (WOW!!)
OH, and new heads from Ford along with an EGR Delete and Oil cooler at 195,000 miles.
DecreasingDave is offline
Old 12-26-2005, 07:49 PM   #2 (permalink)
Re: Where to connect power wire for sat radio (hardwire)
check www.xmfan.com. I purchased this adapter http://www.xmfanstore.com/showproduct.php?id=hardwire
they have them for different radios based on the voltage required. I wired mine into the wires behind the cigarette lighter. clean install easy to do as well. the adapter is fool proof and comes with two easy clip splicers to splice into the wire. I am sure there are some of these adapters that will work for sirius as well.
ebolavirs is offline
Old 12-27-2005, 11:01 AM   #3 (permalink)
Hey Dave,
I just noticed that you have the exact same truck that I have. I also replaced the stock speakers 5x7, but I put in some infinity's. And I have the same JL 10" in a box that I built out of MDF. Enjoy your tunes!!
Regards,
IT [img]/ubbthreads/images/graemlins/smokin.gif[/img]
'03 F-250, Lariat, Crew Cab, 4x4, Toreador Red w/Arizona Beige Two-Tone, Chrome steps. ARE Tonneau cover. SCT Programmer with Xtreme Tune. Donahoe Racing 4.5" lift, 20" EAGLE 114's and 35" Nitto's. MBRP Turbo back. Husky Wood Dash Kit. Python 881XP 2-way responder & remote start. Pioneer AVIC Z-130BT HU, (4)5"x7" Infinity speakers, (2) Alpine amplifiers, (2) Rockford Fosgate 10" subs in custom box.
'99 Honda Valkyrie
'07 Lexus GS350
My Pics
InstrumentTech is offline
Old 12-27-2005, 11:23 AM   #4 (permalink)
Santa brought me a Sirius radio also. I connected mine to the red wire going into the back of the radio. Now it turns on and off with the key. If you have a multimeter just get under the dash and start looking for wires that work. I found a few that work with the ignition, but didn't work in accesory. I just went with the one that I knew would work.
99.5,SC,4X4,DP-Tuner,4"Exhaust,Gauges,Sonnax,Air Raid
dvsing is offline
Old 12-28-2005, 02:03 AM   #5 (permalink)
Thanks.
One more thing, at risk of sounding....ummm....dumb, there are 2 wires going to the power port, 1 black, 1 black w/white tracer. Do I connect one of them to the red wire and the other to a ground?? Which is which?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Thanks,
Dave
- Airaid intake
- Zoodad Mod.
- Doorseal Mod.
- Centramatics
- Timbrens
- Sirius Sat. Radio
Old 12-28-2005, 09:32 AM   #6 (permalink)
Your right. I just used the same chassis ground that my gauges use. I cut the lighter plug off and the all black wire goes to ground and the one with the white stripe will go to a pos. wire that you choose. I was hoping to not have to remove my head unit, but after searching and searching it was easiest to just pull the stereo and use the wire that I knew would work. I've been happy with it so far, but I do wish I could hardwire into the radio instead of using the FM modulator.
dvsing is offline
Old 12-28-2005, 08:03 PM   #7 (permalink)
I used a PIE adapter to run my Sirius radio through my OEM stereo. It works great.
Todd,
Early 1999 (7/98) F250SD, SC, SB, XLT, PSD, 6-Speed, 4x2. AIS intake, Magnaflow exhaust, ISSPRO gauges. DiabloSport Predator tuner.
ToddStyles is offline
