Winches - Diesel Forum - TheDieselStop.com
Old 11-18-2009, 02:09 AM   #1 (permalink)
Matt0987's Avatar
Winches
Any opinions on winches for my Ex and F-350?
What about hydrolic units?
What about the ol' electrics?
Is one better than another? Why?
Is there one that can be hooked up to various vehicles at different times? For example a non-attached portable unit?
What about the ratings? 9000 #? 16000 #?
How does one determine which winch to use?
Do you need second battery? Will a winch drain a battery quicky and leave you stranded?
Do you need to keep the engine running so you don't?
Do you need a more powerful alternator than stock?
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 11-18-2009, 02:02 PM   #2 (permalink)
I can't answer all of your questions but will try afew.I have a Warn 8000lb winch on my 77 f150-has worked great for all these years,if I was buying for a f350 I would go to a 12,000lb or higher.Electric will run down your battery fast under load,you should keep the engine running when under heavy load.The only hydrolic winch I have ever used was on a commerical truck and it was not worth a damn.Ramsey and Warn are the top of the list of brands to buy,there may be others but I am not familar with them.I have a Warn winch bumper on my 99 truck but no winch,The bumper mount allows the factory bumper to be used-it protects the frount of my truck.I hope this helps some,good luck with your choise.
Rich
'99 F-350 Crew DRW PSD Auto Manual-hub 4x4 Lariat BrightAmber Two tone(Prairie Tan), Leather ,Loaded:built 05/98:adopted 06/98
Richard T Rasmussen is offline
Old 11-18-2009, 06:48 PM   #3 (permalink)
Matt0987's Avatar
Thanks Rich
Matt0987 is offline
Old 11-21-2009, 08:24 PM   #4 (permalink)
Whatever you buy, it should be rated at 2.5 times the weight of the vehicle its mounted to. For a jeep for instance, most weigh in at 4k lbs or so. A 9000lb winch is a good choice in this case. For an SD truck, I'd look at no less than the new Warn Endurance 15k lb. electric. As for the electrical system, a good set of batteries such a the Sears Platinum G65 would be fine. All battery cables, connections, etc. should be checked and made sure to be in top working order.
I would avoid the hydralic style at all costs.
2001 F-350 CC 4x4 XLT PSD.,Pro Comp 6.5 suspension, 325/65/18 Nitto Terra Grapplers,18x10 Ultra Chrome Predator 8s, Trenz Grill,AMP Research Power Steps,X-Monitor,BD Pressure-Loc,SCMT,4 in MBRP Stainless exhaust,Tru-Cool Max,AFE Magnum Intake,Wicked Wheel,BRPV,203* stat,Western Diesel Turbo BrakeIII,Sonnax/Tri-springs,1400watt Pioneer/Polk Audio/Fosgate stereo, pre-pump & tank mods,ORU diff covers,acetoned badges,zoodad mod,heater core bypass,Friends of Oceano Dunes supporter, American Sand Association supporter. KEEP THE DUNES OPEN!!!!!
98 Jeep TJ, RE 4.5 long arm,33in MTZs,JB Conv. SS SYE,LoD bumpers,LED lights.
sduncan is offline
Old 11-21-2009, 10:16 PM   #5 (permalink)
Matt0987's Avatar
Thanks Sduncan. I am glad to hear your thoughts. I had been wondering about the capacity rating of the winch.
Matt0987 is offline
Old 11-21-2009, 10:20 PM   #6 (permalink)
Matt0987's Avatar
I had been wondering about the hydralic. In the construction industry I have seen what hydralics can do. So I was considering looking into a hydralic unit. I will look into the Ramsey and Warn.
Matt0987 is offline
Old 11-22-2009, 03:49 PM   #7 (permalink)
CHILLLS's Avatar
warn makes a nice mount that moves the stock bumper out 5" so you keep somewhat of the stock look & aerodynamics.
it also will accept the 16.5ti which is not much more than the 15k.
on the portable mount i would not put anything bigger than 8 to 9k lbs on
the receiver that you are putting it into was not really made to handle that kind of pulling.
just my 2cents worth
good luck with whatever you choose
& i does give you a boost of confidence when your out playing around
02 7.3l psd 6 spd 4x4 cc lb srw
cut muffler
afe stage 2 pro guard 7
wicked wheel
superchips programmer
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
viair 480c compressor
5 gal. tank running 200psi
train horns
firestone bags
piaa supper white head lights
70 gallon in bed tank
warn semi hidden winch mount
warn 12,000 winch
piaa 4" smr fog lights
thats it for now but more to come
CHILLLS is offline
Old 11-22-2009, 06:31 PM   #8 (permalink)
Matt0987's Avatar
chillls, thanks for the input
Matt0987 is offline
Old 11-22-2009, 11:17 PM   #9 (permalink)
mile maker has sevral on the market that is ran from the power stearing pump it will pull the full load at idle and you can get a remote to go with them i have used one many times on fire runs and you cant beat them with a stick.
what good is a elc.wench if you are stuck you get unstuck and now have a dead batt. This is a very powerfull set up and it only takes about half of the space to mount it. the install kit has all the fittings and hoses to make a very prof. install.
just my two cents worth.
firedog533 is offline
Old 11-22-2009, 11:25 PM   #10 (permalink)
BlueMuleTrucking's Avatar
Send a message via AIM to BlueMuleTrucking
I am pretty sure that is why it's mentioned above to leave the engine idling when using an electric winch.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline
Old 11-22-2009, 11:44 PM   #11 (permalink)
Ok i did not see that but most elc.winchs pull about 365 amps when under a full load so it does not make a dif. I still prefer the mile maker other than stressing out my ecl.system like that.
Old 11-23-2009, 06:18 PM   #12 (permalink)
IF and this is a big IF....you go hydralic, be SURE that you consider an upgraded power steering pump, a larger cooler, and change the fluid about every other oil change or so if you use it regularly. I can almost guarantee that you will soon have PS pump issues....
If you want some good winch info, visit some of the jeep forums. Jeep Forum - Jeep Enthusiast Network or www.jeepsunlimited.com The rockcrawlers/extreme trail guys on these forums use their winches more than anybody. There are tons of reviews and opinions from users who ACTUALLY use the winches on some of the toughest trails in the country. You will find few, very few, who will recommend a hydralic over electric winch.
sduncan is offline
