1999-2007 Upgrades and Aftermarket - GeneralUpgrading or adding OEM or aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
I just bougut a 2002 F350 and the guy I bought it from had threw in one of the wireless keyless entry kepads for me to put on. (Part # 3L2Z-14A626-AA ) The problem is that he lost the instructions, and I don't know what the factory default code is to set it up. is there anywhere I can download the instructions?
I think that it might be impossible to do this without the factory default code. To my knowledge, each one has a different PIN from the factory and that PIN is needed to program it to your vehicle.
2003 F-350 Crew Cab, V10, 4X4 ESOF, 4 Speed Auto, Long Box, 3.73 Regular Axle, heavy duty front suspension with W code springs, SRW, Lariat options package- Leather seating for six, cruise, heated seats, single disc player, Chrome tubular cab steps, keyless entry, full power. Newly added- Prodigy brake controller.
And TTT mirrors with heat and turn singal.
Also- Wireless keypad, Century Royal Series Truck Topper and Putnam Class V Trailer Hitch.Truck Photos
Recently turned 32,000 miles.
I had problems getting mine to work [img]/ubbthreads/images/graemlins/shrug.gif[/img], I know its not popular to praise dealerships [img]/ubbthreads/images/graemlins/phoney.gif[/img] by many here but I just stoped by my dealer and he set it up for me no charge no problem [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. Might at least be worth a phone call [img]/ubbthreads/images/graemlins/shrug.gif[/img].
Mark
2003 C.C. 4x4,SRW LB, White over AZ Beige, Complete Banks PowerPak, with Trans Comand,
Exhaust Brake,Edge Juice with Attitude, Custom console, Lerr Topper- AZ Beige,Rhino Liner, flares, Velvet Rides rear sway bar,IAS shocks Firestone Ride Rites, AIC, AFE Stage II, 203 thermostat with Billet housing,Coolant filter, Super Crewzer Badges,C-betr mirrors, Fireman LED lite bar, Power slider, Heated mirrors & Seats Reverse senors, Cab lites, Vent shades,SS door & Tailgate handles with power lock tailgate, APC Projectors with Britebox,Silverstars,PIAA 24 Silicone blades,JL 6x9's all around,XM radio, w 11 inch LCD drop down, Woodgrain dash kit, Keyless entry,Brakesmart controller,Mag-hytech Trans pan, Trans cool with filter, Weld Cheyene 8 Xt's with Nitto Terra Grapplers, Lots of Chrome and Billet. Kenwood DVR Head unit with full navigation system with screen in back of head rest as well.
Pics of some of MyToys http://www.dodgestang.com/toys.htm
I anticipate that it ability be absurd to do this after the branch absence code. To my knowledge, anniversary one has a altered PIN from the branch and that PIN is bare to affairs it to your vehicle.
I had a problem with programming my wireless key pad and here is what i did to fix it. First u need to get all the key fobs that go to the truck. put your key in the ignition and turn it to the on position(don't start the truck) go from off to on 8 times. on the 8th time (in the on position) the doors will lock and unlock to confirm you are in the program mode. hit the lock button on each fob after each key fob it programmed the locks will lock. do this to all the key fobs. now to program the wireless remote type in any 5 digit code you want. the locks will also give u a conformation they respond to the new pad. once everything is programmed then turn the truck off and take the key out. you can test all the fobs and then enter your code on the key pad.. they all should work. here is a fyi if u press the last 2 buttons on the keypad it will lock the doors on the truck also after u out in the 5 digit code the drivers door will unlock if u hit the 3 button after the 5 digit code it will then unlock all the doors. good luck hope this helps.
2006 Ford F250 6.0 Diesel CC Longbed, 6" Superlift, 325/60/R20 Nitto Grappler tires mounted on Jesse James Lawless rims, Airaid Intake, 4" Turbo Back Magnaflow Exhaust, Amp Research Running Boards, Bushwacker Pocket Style Fender Flares, 3pod pillar Glowshift Gauges, Recon Xtreme Tailgate Light Bar, Remote Start
02 F-350 Reg Cab Auto Trans L2 Blue, Marinco Mod, ZooDad Mod, Bilstien HD Shocks, Ford Alarm Code 3 Remote Start, Energy Suspension Spring Bushings and SwayBar Bushings, 2500 Watt Inverter, Sirius Sat. Radio, (Hardwired), Garmin Nuvi 250 (Hardwired), Blue Sea 6 Circuit Fuse Panel X2, Western 8' Pro Plus Ultra Mount Plow, 08 Taillights, Stancor Mod, Ford AIC, AIH Delete, Stainless HPX, Foil Delete, 05 PTM Tow Mirrors, 05 Upfitter Switch, 05 Center Dash, Federal Signal Smart Siren with Signal Master...
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
