Angel Eyes can be installed on any vehicle as an accent for your headlights. They can be found on BMWs and are a nice modification for any vehicle. Diode Dynamics' angel eyes are the highest quality and brightness available. We encourage you to shop around, you will not find better angel eyes for these prices! Our rings were custom-designed for reliability and long life, and have been tested on your vehicle for perfect fitment.
Our multicolor rings use SMD technology, a modern type of LED that provides a bright forward-firing light, creating a circle of light inside the headlights.
RGB MULTICOLOR angel eyes come with a remote control, in order to pick the color or effect you want. The controller has a static memory, so you can leave the angel eyes switched to WHITE for every time you start your car and drive around, then get out and change up the color! They also come with a custom wiring harness, for plug-and-play wiring, and a standard RGB controller unit with remote. We also offer a WIFI controller option which allows you to control them via smartphone app.
Kit includes:
Four (4) 5050-SMD Rings, fitted for your vehicle
Diode Dynamics Plug-and-Play Wiring Harness
Installation guide
Three year replacement warranty
Installation
Installation requires you to open the headlight, by using heat from either your oven or a heat gun. It sounds bad, but really isn't too hard. Simply remove all screws, heat the seal, and pull apart. We have installation videos and other helpful guides available at diodedynamics.com/install. The wiring is a plug-and-play installation, using our Diode Dynamics Angel Eye Harness and quick disconnects. You will not have to do any soldering, wire stripping, crimping or anything. Our wiring harness makes wiring a breeze!
Don't want to do it yourself? Looking for a kit for a different model? We can do any vehicle for you, with our large inventory of ring sizes. Contact us for information.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Diode Dynamics is excited to announce our new HD LED Halos and Semi-Flex Strips are now available! Offered in switchback and single colors (red, amber, blue and white), they are perfect for custom applications! The Strips are available in 3, 6, 9 and 12 inches and the Halos are offered in universal sizes from 50-160 millimeters.
Both products were designed from the ground up and manufactured in our facility here in St. Louis, Missouri. They are backed by our hassle-free 3-year limited warranty.
Introducing Diode Dynamics Butyl Headlight Sealant! This sealant rope was designed specifically for headlamps, with a firmer composition than auto-store windshield glue. This makes it easy to work with, without causing a sticky mess.
Use it to reseal any headlamp after installing Diode Dynamics LED products! Warm it up a bit, stretch it into the headlight channel, and clamp together while heating, making sure the lens is fastened to the housing. With a little practice, you'll have a factory-quality seal, with quality butyl that will protect against moisture ingress for years to come.
Discount cannot be combined with other offers or any previous orders. Expires at 11:59 p.m., July 6th, 2018.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
