Ford F250 / F350 Reverse/Backup LED Bulbs! Plug & Play! Ships Same-Day - Diesel Forum - TheDieselStop.com
post #1 of 61 (permalink) Old 12-23-2014, 03:35 PM Thread Starter
Supporting Vendors
Diode Dynamics's Avatar
Arrow Ford F250 / F350 Reverse/Backup LED Bulbs! Plug & Play! Ships Same-Day
Ford F-250 / F-350 Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your reverse light or backup light bulb (921 / 3156 size). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your model year selection.
Bulb Design
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Fitment. 1997-2010 F-150 Model Years / 1999-2006 F-250 & F-350 Model Years(3156) use a quality inject-molded 3156 terminal, with a locking base connector and proper pin alignment, designed for exact replacement of your factory 3156 bulb.
2011-2014 F-150 Model Years / 2007-2013 F-250 & F-350 Model Years (921) use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP11: Slightly higher brightness than OEM bulbs.
XP80: Much brighter than OEM bulbs. These are bright!
HP5: Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP36: Slightly higher brightness than OEM bulbs.
XP50: Much brighter than OEM bulbs.
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Customer Reviews:
"These bulbs are very bright and the quality is excellent. I am very happy with all my dealings with this company. (Posted on July 24, 2014)" -Mike
Diode Dynamics is offline
post #2 of 61 (permalink) Old 06-12-2015, 08:43 AM Thread Starter
Supporting Vendors
post #3 of 61 (permalink) Old 07-23-2015, 01:29 PM
wHAT, IF ANY, PART NUMBERS FIT 2000 fORD eXCURSIONS?
God Bless America!
2014 Chevrolet VOLT
2000 Ford Excursion 4X4 PSD Limited
1986 Ford F250 4x4 Supercab, long bed , 6.9L/AT
2001 "MagneticRed" Corvette Coupe
1979 Pontiac Y84 "Bandit" Trans Am
1988 Lincoln Mark VII LSC
1996 Chevrolet Impala SS Dark Cherry Metalic
1996 Chevrolet Impala SS Black
1995 Buick Roadmaster Sedan
mikeceli is offline
post #4 of 61 (permalink) Old 07-23-2015, 01:32 PM Thread Starter
Supporting Vendors
Give us a call and we can assist you in finding bulbs to fit your 2000 Ford Excursion
Might want to turn off the caps lock for future posts
Nick C.
post #5 of 61 (permalink) Old 10-16-2015, 04:46 PM Thread Starter
Supporting Vendors
Meet our newest LED bulb replacement, the HP48:
Available in 1156/7 - 3156/7 - 7440/3 sizes
post #6 of 61 (permalink) Old 03-09-2016, 10:03 AM Thread Starter
Supporting Vendors
post #7 of 61 (permalink) Old 04-08-2016, 08:48 AM Thread Starter
Supporting Vendors
post #8 of 61 (permalink) Old 05-17-2016, 08:31 AM Thread Starter
Supporting Vendors
post #9 of 61 (permalink) Old 05-19-2016, 09:42 AM Thread Starter
Supporting Vendors
XP50 Output Shot - 2016 F-350
Nick C.
post #10 of 61 (permalink) Old 01-12-2017, 01:54 PM Thread Starter
Supporting Vendors
PM Responses sent!
Thanks,
Nick C.
post #11 of 61 (permalink) Old 01-20-2017, 10:16 AM Thread Starter
Supporting Vendors
post #12 of 61 (permalink) Old 01-23-2017, 09:15 PM Thread Starter
Supporting Vendors
post #13 of 61 (permalink) Old 01-25-2017, 04:09 PM Thread Starter
Supporting Vendors
PM Responses sent!
post #14 of 61 (permalink) Old 01-26-2017, 11:40 AM Thread Starter
Supporting Vendors
Don't forget to send us a PM for the free-shipping code!!
(U.S. members only)
Thank you,
Nick C.
post #15 of 61 (permalink) Old 01-30-2017, 08:57 PM Thread Starter
Supporting Vendors
Diode Dynamics: Authorized Dealer Locator Tool
Looking for professional installation? We've added several new authorized dealers to our locator map!
Nick C.
  Diesel Forum - TheDieselStop.com > Supporting Vendors > Diode Dynamics
