Pull the vacuum line off the pump. Can you hear vacuum leak off? Turn the key to the run position. Does the vacuum pump come on. If the pump runs, but you had no vacuum when you pulled the hose off, there is a vacuum leak somewhere. If the pump doesn't run, check the fuse. If the fuse is good, replace the pump. If fuse is blown, replace fuse and see if it blows it again. If it does, replace the pump. The most common area for a vacuum leak is under the dash on the passenger side where the hoses connect. Hope this is helpful.
2002 F250 crew cab
