2000 F-350 7.3L Gem module - Diesel Forum - TheDieselStop.com
post #1 of 25 (permalink) Old 07-22-2008, 01:14 PM Thread Starter
I have a 2000 F-350 crew cab 7.3L with 112,000 miles. About 3 months ago I started having problems with my power locks both key fob and door switch intermittingly locking/unlocking my doors. The same period of time intermittent problems with my drivers power window working slow both up and down. Since March of this year have been thru new calipers both left and right side 2 times with no ABS indicator lights, mechanic states calipers are moving freely. This past Friday after driving 25 miles the drivers side rear wheel was smoking and rim was HOT to the touch with a brake smell, did not feel the brakes hanging up, the vehicle sat all weekend. Heavy rains and severe t'storms hit the area on Sunday. Monday morning got in the truck (keys not in the ignition yet) and the fan (a/c) was blowing cold air, drove the truck about a mile and the overdrive off light was flashing on and off about another mile down the road the speedometer stopped working and then was working intermittly during the 25 mile trip, when reahing the destination all hubs were cool (no brake hangups) and it was pouring rain. The mechanic hooked up a scanner and it said it was the speed control sensor. With all the other problems could it be the GEM module? The windsheild has not been replaced/repaired and no knowledge of any leaks. Thanks in advance. Ed
firefighterEd is offline
post #2 of 25 (permalink) Old 07-22-2008, 02:47 PM
klhansen's Avatar
My Photos: (180)
Welcome to TheDieselStop.
The GEM doesn't have anything to do with brake problems (you mentioned sticking calipers), except to control the brake failure indicator light. It doesn't even control the speedometer.
The speed sensor sends it's signal to the ABS module, which relays it directly to the speedometer in the cluster, bypassing the GEM.
The window motors, door locks and AC fan are controlled by the GEM however, so THOSE issues may be caused by a GEM that's taking a bath from leaks.
I'm moving your post to General Questions, as its not specific to the engine.
), AIS,
regulated return,
klhansen is offline
post #3 of 25 (permalink) Old 07-23-2008, 03:29 PM Thread Starter
So why did I lose my speedometer? I do believe the GEM is the culprit for the other items messing up, there are no leaks in the vehicle. Thanks Ed
post #4 of 25 (permalink) Old 07-23-2008, 03:48 PM
klhansen's Avatar
My Photos: (180)
Sometimes things just break (VSS).
You could be right on that. It wouldn't necessarily take a leak for the GEM to go bad. (see comment above).
), AIS,
regulated return,
klhansen is offline
post #5 of 25 (permalink) Old 07-23-2008, 09:09 PM Thread Starter
If it was the VSS shouldn't there be an ABS code or light? Should the VSS also be changed as well as the GEM? Thanks, Ed
post #6 of 25 (permalink) Old 07-24-2008, 12:37 PM
`Jeff`'s Avatar
Send a message via AIM to `Jeff` Send a message via Yahoo to `Jeff`
I have a GEM Module that has never taken a bath yet lost the power window / Accessory Delay function last week. Go figure. Trying to find a tech to re-flash it before I spring for a new one.
`Jeff` 99 F250 PSD SC LB 4x4 Auto Lariat (Built 7-98) PMT1 PCM, 4 Pos DP Tuner, Propane, 10K Mod, BTS Transmission & Converter, 4" SS Exhaust Turbo back, Fuel Regulator Shim Kit & Gauge, KCM S.S. HPX, Cold Air PVC/AFEII, Pre-Pump, Tank Mod & Harpooned, CCV Mod, 2005 Headlight Conversion w/HID, 900 watts of Landing Lights, 3" Steel Cowl Hood, 6" Lift, 16 x 10 DC-1 Black w/35" Nitto's, WARN Hubs & Loaded with TOYS! 3/09 - 185,000 - CRACKED PISTON, CRACKED CYLINDER SLEEVE, BROKEN FLEX PLATE... $1045.00 Ford Master Rebuild Kit, $1400 Machine shop invoice for new sleeve, install cam bearings, rebuild heads, about 35 hours of sweat-labor... Having a fresh motor that's quieter than it ever was new.... NOT PRICELESS, $3200! BUT WELL WORTH IT!
AE/FORD ENHANCED - IN THE CHICAGO AREA
`Jeff` is offline
post #7 of 25 (permalink) Old 07-24-2008, 03:11 PM
I too have am having issues with my GEM. The door locks randomly work and I recently lost the control of my window switches. I was able to jumper past them to get the windows rolled back up, but there is no power going to the switches. I have read somewhere on the web that there was TSB for these trucks regarding the GEM. I believe it was that they were located in a place that they were more susceptible to water damage from the windshield. I have not been able to verify this. Where is the GEM located??
timberwolf223 is offline
post #8 of 25 (permalink) Old 07-28-2008, 01:50 PM
`Jeff`'s Avatar
The GEM is screwed to the back of the fuse panel under the dash.
It comes out in about 10 min with the right tools. Hardest part is unscrewing the bulkhead connectors from the fuse panel.
`Jeff` is offline
post #9 of 25 (permalink) Old 07-30-2008, 05:31 PM
Thanks. I will try to remove it and see if there are any issues with the connectors or such. Has there been any sucess with re-flashing the GEM to get them to come back from the dead?
post #10 of 25 (permalink) Old 12-22-2008, 11:27 AM
Same issues....
It has to be the GEM because I have had the same exact problems with my 2000 F350 4X4 7.3L manual. Heater blower motor on one morning, no speedometer indication, no 4X4, etc.
dvjv is offline
post #11 of 25 (permalink) Old 12-22-2008, 11:29 AM
My GEM has never had water on it since I have had the truck (4 years) but it continues to do strange things.......
dvjv is offline
post #12 of 25 (permalink) Old 01-01-2009, 10:00 AM
Fixed ESOF 4X4
My four wheel drive system works flawlessly now that I found the lock portion of the shift motor encoder connector broken. The connector had slid back off the encoder approximately 1/8th of an inch. 4X4 would self-test OK on startup but no shifting. Tried to glue connector lock back on but wouldn't hold. Fix was to drill (3/32) throught the lock portion of connector and socket while holding on firm then slide 3/32 cotter pin through.
dvjv is offline
post #13 of 25 (permalink) Old 02-21-2009, 12:49 PM
tturbonegro's Avatar
i think my gem is draining my batteries...does the truck have to be hooked up to machine or anything after installing new GEM or will it configure itself?
work: :00 f350 xlt super duty: banks big head, 5" turbo back, banks tans command, s&b intake, leveling kit, 33" m/t, recon smoked cab and led's, etc..
play: :01 audi 225 coupe: heavily modded..
tturbonegro is offline
post #14 of 25 (permalink) Old 02-22-2009, 09:50 AM
I installed a new GEM in my truck during troubleshooting and everything "seemed" to operate correctly without configuring/machine hookup. I have since removed the new GEM and reinstalled the original because the 4X4 problem was the connector at the transfer case and not the GEM. The other odd problems (heater blower staying on, etc.) have been fixed since disconnecting all connectors to the GEM and reinstalling. In my business that happens alot (disconnect/reconnect, problem goes away).
dvjv is offline
post #15 of 25 (permalink) Old 02-22-2009, 11:37 AM
Banned
dvjv... I am not sure of what business you are in.... and neither is anyone else.
If disconnecting a connector and then reconnecting it "fixes" a concern, it is time to look closer.
Module communications deal with very low voltages and very low current flows. In the computer world, it doesn't take much of a concern to wreak havoc...
So... what business are you in?
On edit.... replacing a part (in this case the GEM) is going to be hard to call "troubleshooting". We diagnose a concern to avoid replacing parts unneccessarily... Replacing parts uneccessarily to diagnose a problem is hardly progress.
Call me an ass...
GrampyJim is offline
