2000 F350 7.3 powerstroke no electrical - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 09-21-2012, 10:33 PM Thread Starter
ok, was using truck shut it off ran into a place came back out and I have no electrical power what so ever, both batteries are testing 12.5 but I have no electrical any where, head lights dont even turn on any ideas, and please specify a location of any fuseable links or relays I need to check.
phill99337 is offline
post #2 of 2 (permalink) Old 09-21-2012, 11:24 PM
klhansen's Avatar
My Photos: (180)
Welcome to TheDieselStop
Look at the starter relay on the passenger side fender just behind the battery. That's the main connection point for power. There are two wires there each with two fusible links there that supply power to 2 places, the GPR, IAHR and Alternator, and toward the rear over to the main Power Junction box on the driver's side. You should also check the main connection there on the front of the box. There's a cover there that slides up to uncover the terminal.
), AIS,
regulated return,
klhansen is offline
