2001 Ford F350 SD Crew Cab - Tire Jack - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 04-02-2005, 09:16 PM Thread Starter
I bought my 2001 Ford F350 SD Crew Cab used, it didn't have a tire jack to change the spare tire. Where can I buy a new or used one? (other than the dealer). Any help would be appreciated. I have the rods under the hood, but the jack from behind the rear seat is missing. I also need to know where the tire iron is stored. I haven't seen it either.
Thanks for the help.
shawv is offline
post #2 of 3 (permalink) Old 04-02-2005, 09:55 PM
My Photos: (21)
Re: 2001 Ford F350 SD Crew Cab - Tire Jack
The tire iron is stowed under the hood along with the rods. 1stFord Parts will work as a source or hit up the junkyards in your neck of the woods. And if you need an owners manual, surf over to Motorcraft.
O
02/03 built
6L, DRW,
, 4" DPPI Exhaust, UltraLites on the
and
, Firestone Bags & Compressor,
, 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0,
, XM Commander.
ozhoo is offline
post #3 of 3 (permalink) Old 04-02-2005, 11:52 PM
The tire irons should be above the radiator. See pic,
http://www.supermotors.org/registry/...amp;original=1
If you mean the stock tire JOKE is missing, you are for the better. There is no reason a dinky little jack should be sold with these monsters. For your own safety, go out and buy a good three ton jack with stands.
Adrianspeeder
adrianspeeder is offline
