1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Overhead console sunglasses door latch is broken. The whole assembly needs to be replaced. Purchased part, but dealer says I will brake the electronics because I don't have something I need. Has anyone done this replacement. Please advise.
2002 F-350 SC, LB, 4X4, SRW, Arazona Beige Clearcoat Matallic, Lariat, 6-Speed, with Timbren Rubber Spring on the back end. Pulling either a Alpenlite Rivera 29RK or a R-93 Ranger Bass Boat.
Not to sound like I'm telling you how to do something but.....if it's the latch for the door, isn't the latch ON the door? So don't you have to replace just the door? Mine broke too and the door cost was $80!! I think the cost of the whole overhead was half that.
Luckily, my doors were broken (yes, both) when I had stereo work done and the guys broke the overhead when they did their work. They replaced it and now I don't use the doors anymore.
2002 F-250 Lariat 4X4 Auto PSD CC SRW. Banks 4" Monster Exh, aFe Stage II w/PG 7, TAG II + Hi-Perf Comp Wheel, X-Monitor, SCMT 1705, fuel tank and pre-pump mods, harpooned tank, Zoodad air, always bright overhead, SUV-Lights harness + silverstars + SteveRacer mod, fuel regulator shim, HX oil hose, 2003 Lighted Mirrors, 203* T Stat, Rancho 9000s, C-Btr Mirrors, Roll-N-Lock bed cover, Brakesmart and Titan V. 6.0 Tranny Cooler
Need help having hard time starting. fuel pressure 50 when key turned on . after pump turns off pressure bleads off...while running fuel pressure at 50 .....when i do get it started in the morning sounds like its running on 4 cyl for about 1 min then it clears up ...icp pressure is good over 500 when starting ...and sug or tech info..
Ok, what did you do. I don't want to break anything electronic. If you remember let me know specific steps, because nothing wants to come loose easily.
Thank you.
Monty
You did'nt make it clear as to what "part" you purchased. If you're replacing the whole console, just pry evenly around the perimeter of the console - it's only held in place with spring clips, there are no screws involved. There are no electronics, wires, etc attached to the console either. You'll see what I mean when you remove it. As for the door, if you only want to replace that, then you'll have to snap it into place of where the old one was.
Not so, as one of those doors takes a screw to get it off. You'll need to pop off the entire console and then undo the screw. It's cheaper to get an entire complete console than to buy just one door. Crazy, but true.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies. pappy's truck
"So" - just had a look at my manual as well as my console (the one I removed), as well as a a couple of websites, and I don't see the screw you refer to. The only screws I see are the ones holding the black sub-console (with the electronics, etc), underneath the outer console. Of course, you don't need to remove that to do what Mbonn21 wants. Here's a pic and description of someone elses removal, which describes the procedure as: "This was the nerve wracking part. Just tug on the plastic cover for the overhead console to pop it loose. It sounds like it's breaking apart, but it's just the clips coming loose."
Thank you everyone who helped answer my questions. It's 90+ degrees outside, so I will wait until this evening or early tomorow to do it, but now I don'w worry so much about breaking anything.
Monnty
Roadfrog-I am referring to the rear door, it has a screw to get it off. The entire console pops off, no screws. The front door doesn't have a screw, but it's still better to take the entire colsole off to replace as the little ears are easy to break.
