2003 F250 6.0L Simple Oil Question - Diesel Forum - TheDieselStop.com
Old 11-20-2012, 02:39 AM   #1 (permalink)
Thumbs up 2003 F250 6.0L Simple Oil Question
Going to be doing a oil change on my 2003 F250 6.0 with 173,000 miles on it, I know the book says to use Motorcraft oil's but I just want an opinion from others what you guys run? Mobil 1? Vavoline? Rotella? I live in South FL so it gets pretty hot, cold at times but not lower than 45 for the most part only during winter.
JB772 is offline   Reply With Quote
Old 11-20-2012, 06:07 AM   #2 (permalink)
badbart's Avatar
The answer is yes. Actually I use Motorcraft, but many others here use Rotella. As long as it meets specs they're all good. I just use Motorcraft because that's what Ford recommends.
1997 F350 XLT Crew Cab Dually, 7.3 Powerstroke, 4:10 limited slip, K&N Air Filter, MBRP 4" Turbo back w/muffler, Edge programmer, Billet torque converter, Monster tranny cooler.
2004 Cadillac CTS V 5.7 LS6, Tremec 6 speed,
K&N Cold Air, Magnaflow Exhaust, MSD Ignition,
LS7 clutch, Getrag 3:73 posi-trac, 377 RWHP
badbart is offline   Reply With Quote
Old 11-20-2012, 08:52 AM   #3 (permalink)
Take your pick, most any oil meeting the API service grade of CJ-4, and with the correct viscosity range, will serve you well.
I can tell a difference with my 7.3 at start-up if I use 5W-40 synthetic. It's thinner than 15W-40 when cold, and feeds the injectors slightly better until it reaches operating temperature.
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump.
txgp17 is offline   Reply With Quote
Old 11-20-2012, 02:26 PM   #4 (permalink)
Being that I don't really live in a cold climate except for a few months out of the year mainly at night should I still put in 5w40 or should I use 15w40??
Old 11-20-2012, 05:09 PM   #5 (permalink)
bobsherrie's Avatar
If it was me I'd use any good 15w40 since you aren't in a cold climate. I am in a cold climate and use 15w40 in the summer and 10w30 in the winter. Many believe in a synthetic but since I change twice a year I can't justify the extra cost. TJMO
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline   Reply With Quote
Old 11-22-2012, 08:28 PM   #6 (permalink)
In FLA I would use Rotella T 15/ 40
This year in Wyoming I changed to Rotella T 6 - 40 synthetic ...at - 5 degrees without being plugged in the truck starts up and just purrs from the start. With 15/40 at that temp. it would lope and rock for a min. before the oil thinned out.
brooks379 is offline   Reply With Quote
Old 12-02-2012, 09:10 AM   #7 (permalink)
And don't use cheap aftermarket filters, they don't meet specs. There are YouTube videos out there that show how bad they can be.
2003 6.0L F250 XLT S-Cab 4x4 FX4 White/Black
my97TJ is offline   Reply With Quote
