2005 6.0 diesel wont start when hot - Diesel Forum - TheDieselStop.com
Old 11-01-2009, 06:25 PM   #1 (permalink)
My 05 6.0 Turbo Diesel Will Cold Start Fine But When It Heats Up And I Shut It Off It Wont Start. It Cranks But Wont Turn Over. In An Emergency Once I Shot Some Starting Fluid Into The Air Filter And It Started Right Up. Im Reading No Codes On The Scanner.i Was Expecting To Find A Cps Fault Or Ips Fault Can These Still Be Bad With Out A Code? Can Anyone Help Me. I Also Changed All Fuel Filters Thinking They Were The Problem. Help
PAULBOY is offline
Old 11-01-2009, 09:19 PM   #2 (permalink)
Since its an 05, the most likely cause would be the STC Fitting leaking on the HPOP.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 11-02-2009, 06:25 AM   #3 (permalink)
Hpop? Is That The High Pressure Oil Regulator
PAULBOY is offline
Old 11-02-2009, 09:28 AM   #4 (permalink)
RatherBNtheWoods's Avatar
Close. It's the High Pressure Oil Pump. It makes around 5000 PSI of lube oil pressure to operate the injectors.(HEUI type injectors).
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 11-03-2009, 03:29 PM   #5 (permalink)
I'll go with DRJ on this one and say at the very least it's HPO related. When the truck warms up the oil gets thinner which isn't really an issue as the truck is running. If you go to restart though it'll be tough to fire those injectors.
04 F350 lariat, PSD, AT (the toy hauler) SCT X3 by IDP, Silverline T409 Dual 4" Turbo back exhaust w/no muffler, AFE Stage I, ARP's, black onyx HG's, Alpine W205 DVD player/nav/rearview cam, JL Audio Stealth box w/10" W3v3, Alpine amps x2, Alpine 5x7's all 4 corners, 20% tint, hard tonneau, harpooned, zoodad mod..
The Toys:
2 '91 SHO's, '97 SHO, '00 Suzuki GSX-R 750, '03 Yamaha RX-1 Mtn
sho91mtx is offline
