2006 f250 instrument cluster light replacement?? - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-26-2010, 08:42 PM Thread Starter
6.0believer's Avatar
Hopefully you guys can help me...Is there a write up anywhere about changing a bulb in the instrument cluster? how hard is it to do? Any and all info appreciated.
Thanks!!
2006 F-250 6.0 Auto XLT 4x4 EC LB Tow Command
SCT X3, tuned by IDP, ARP Headstuds, FPR Blue Spring Kit, E*R deleted, High Idle Mod, Dfuser Coolant filter, Upgraded HFCM Plug, B&W GN, Timbren SES, Ed's 48v FICM w/ PHP Atlas 40 tune, MBRP 4" SS turbo back w/ no kitty, and Edge CTS w/ EAS & EGT
6.0believer is offline
post #2 of 2 (permalink) Old 08-29-2010, 03:41 PM
woodnthings8's Avatar
Not sure if yours is much different than my '02, but you just remove the dash cover, which pops off, you will need to pull a few of the switches first. Then the instrument cluster is held in with 4 screws. With an auto, you have to pop out the shifter indicator, but it is just a plastic catch. Then you should be able to access all the bulbs.
They are 4 years apart so you may find differences, but not too much...hopefully
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
