Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 05-21-2006, 04:07 PM   #1 (permalink)
2wd ball joint replacement
Looking for info on replacing upper ball joints. Manual says as of printing no replacement . Surely somebody knows how.
99 std cab auto 4 inch muffler delete homemade tymar ccv mod 1705 superchip trans temp pyro. 03 flhtcui
workman is offline
Old 05-21-2006, 04:58 PM   #2 (permalink)
Re: 2wd ball joint replacement
Do a search on this site. Someone has the replacement procedures posted for a 4WD. They will give you all the data you need for the job on a 2WD. NAPA or another good parts place can provide Moog replacement ball joints to fit your truck. I did mine last year using those instructions.
Early 99 F250 PSD (XLE4) XLT, Extended Cab, Short Bed, 4X2, BTS Trans/TC, 3.73 Limited Slip, Transfer Flow 48 Gal. Mid-Ship Tank
Western WA - Member since August 2001
FleetMan is offline
Old 05-21-2006, 09:23 PM   #3 (permalink)
It's really pretty straight forward. Mark the caster pills before you disassemble so it will be close on reassembly. I knocked the old ones out with an air hammer, and pressed the new ones in, took about 1 hr per side.
FS
'01 X 7.3 to tow my racecar...
AIS w/ sleeve
S.S. HX(removed for now)
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
Landyot's Radius Rods
DP Tuner-80E, Hi Idle, 60 tow
EGT, Trans temp, boost gauges
'99 E350 Snake Oil Wagon, 200+K, doesn't burn oil, lives on the bump stops & has a hard life. Runs like new.
'91 Spec Miata
All vehicles full of BG Synthetic Fluids
fastersteve is offline
Old 05-21-2006, 10:11 PM   #4 (permalink)
Did you have to completely disassemb to install.Could you have pressed ball joint out.
workman is offline
Old 05-21-2006, 11:01 PM   #5 (permalink)
Had to take the rotors, backing plates, ABS sensor & tie rod off the steering knuckle, knuckle off the truck. Could've pressed the old ball joints out, but just as easy to drive them out with the air hammer or a BFH. You might as well do uppers AND lowers while you have it apart.
FS
AIS w/ sleeve
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
'91 Spec Miata
