7.3 Interior light - Diesel Forum - TheDieselStop.com
Old 04-30-2009, 06:13 PM   #1 (permalink)
7.3 Interior light
1999 F350 dually dump. Hey my dome light won't go off! Its cause by the passenger door. where is the trip sensor on the passenger door? By the hing or the other end?
Hey my truck is running Sweeeet. Last month we found a bad clip connector on the IPC. Solved about a year of off and on symptoms with a $1.00 connector.
magill810 is offline
Old 04-30-2009, 06:17 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
Check this thread Weird door ajar problem (Stickied at the top of the 99-03 General Questions forum)
Hard or no-start? Check Here
klhansen is offline
