ABS light on - Diesel Forum - TheDieselStop.com
Old 10-15-2009, 03:58 PM   #1 (permalink)
bade's Avatar
ABS light on
My abs light has been on for about 6 months. I can bleed the brakes and it will go off for a minute and come back on . Anyone have an idea of what I can do. Brakes work fine just aggrivating.
2008 F-350 4X4 Offroad Crew cab 6.4 diesel. 2 1/2" leveling kit , S&B CAI , H&S XRT Pro , Diamond-eye exhaust ,Sinister egr blocking kit, Air-Lift air bags , B&W gooseneck hitch , Draw-tite fifthwheel fitted to gooseneck hitch. Dragging an 05' 35' Sierra triple-slide Fifthwheel
bade is offline
Old 10-15-2009, 07:54 PM   #2 (permalink)
F250crazy's Avatar
Likely not a bleeding problem. Have you had the system open for any reason besides bleeding? Does it come on after start up with the truck not moving or does it come on when you move? Makes a difference for diag purposes. If it comes on when not moving and right when you start itis will likely be a control problem ie computer. If it comes on when you drive a few feet the problem is likely a wheel speed sensor.
F250crazy is offline
Old 10-15-2009, 08:00 PM   #3 (permalink)
ckanderson's Avatar
AE should be able to read the code
2002 F-250 7.3 4x4
1964 Nova 400 w/350
ckanderson is offline
Old 10-15-2009, 10:16 PM   #4 (permalink)
Had the light come on in the DRW a while back. The light would be on about 95% of the time and when the little didn't come on was when things didn't feel right. The brakes would pulsate and feel really spongy when the light was not on. I'd quick turn the truck off and back on and usually the light would come back on and everything worked fine.
My mechanic ran the code for the speed sensor in the rear axle. $25 part, not too bad.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod
00 BMW 328CI 2dr silver fully loaded
65 Mustang 289 V8 4brl
69 GTO 400 4spd
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
