There are also two additional ABS sensors in the front hubs. These can go bad as well. Then there are a couple internal on the transmission. But the main ones are the two up front and the rear diff. If you can have someone with AE scan for codes they would come up.
Plus you could run AE and check all three speed sensors and see if they are all reading properly. If one doesn't work right they all are screwed up.
One question.... do you have some type of speedo recalibrator in your truck .. like a Superlift truspeed?
01 F350 CC LB 4x4 SRW,(w/forged rods), 12.5" Lift, OUO Traction Blocks, Dynatrac Prosteer Ball Joints, SPYNTEC Conversion, 40"ToyoMT, 22"MKW M19's, Hybrids, GTP38R 1.15, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
Truck Pics
Old Truck Pics
