AC coolant bypass valve or cutoff valve - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-19-2017, 04:55 PM Thread Starter
hey all, I noticed that the heater control valve has a barb with no hose hooked to it . I do not see a hose around anywhere and am not sure where the control side is or where it supposed to attache to. All data doesn't show me anything and doing searches shows different valves. Im wondering since my truck is a half year it could be the reason for a different looking part . Could explain why max ac inst much better the regular ac haha.
my truck a 2003 7.3 4x4.
thanks in advance for any help
looking at it last night, the vacuum lines run off the vacuum hub switch and one line run towards the back over the fan housing which I believe is for the recirc door. should there be a T in there on line to run t the valve ?
Name:	ac valve.jpg
ID:	108305   Click image for larger version
Name:	vauum line 2.jpg
Robert Stoner is offline
post #2 of 6 (permalink) Old 04-25-2017, 06:54 PM Thread Starter
nothing? its a tough one
post #3 of 6 (permalink) Old 04-25-2017, 07:54 PM
RT
RT's Avatar
I'll take some pictures of mine in the morning when it's light out. Mine is an 03 as well.
Sent from my iPad using Tapatalk
RT is online now
post #4 of 6 (permalink) Old 04-26-2017, 01:46 PM Thread Starter
AWESOME! thank you
post #5 of 6 (permalink) Old 04-26-2017, 05:44 PM
RT
RT's Avatar
The grey tube from the valve goes straight to the passenger fender liner and down the side of the fan into the cab. The last picture is behind the glove box. I haven't pulled lines to see which is which inside.
AC coolant bypass valve or cutoff valve-imageuploadedbyag-free1493246652.916295.jpgAC coolant bypass valve or cutoff valve-imageuploadedbyag-free1493246670.415817.jpgAC coolant bypass valve or cutoff valve-imageuploadedbyag-free1493246684.113964.jpgAC coolant bypass valve or cutoff valve-imageuploadedbyag-free1493246695.647458.jpg
Edit - looking at your second picture, the grey tube is there. You just need to find out where the end is and plug it in.
RT is online now
post #6 of 6 (permalink) Old 04-27-2017, 10:35 AM Thread Starter
Attachment 108545Attachment 108553Attachment 108561Attachment 108569
AWESOME thank you so much! Now, on to the next part where to get the hose haha. going to fun to explain to the parts guy
