AC not working need help - Diesel Forum - TheDieselStop.com
post #1 of 131 (permalink) Old 06-17-2007, 08:16 PM Thread Starter
Hi Guys
I have had to many problems since yesterday. My Fan/AC was working great yesterday and all night. I drove 260 miles round trip hauling a horse to Hesperia CA.
This morning when I popped the hood to check on something else I noticed a hissing noise coming from the passenger side near the AC components. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
When I came back in the afternoon their was no hissing sound when the truck was off. When I started the truck and turned on the fan It was blowing out warm/hot air (probably the ambient air temp of 72 degrees) I let the engine warm and then I turned it on again its still blowing out warm air on the coldest setting if I turn it up to the hot setting it blows out hotter air like it should but if turned to the cold setting it blows out warm air.
Also I took a look at the AC compressor and their was a circular gear if you will that would spin for 2 seconds then stop and it would keep doing that cycle.
Whats the deal with my Fan and AC not working properly,
I appreciate the help
thanks,
Andrew
Ford F550 Crew Cab 4x4 with Fontaine Bed and Air
00PSD1 is offline
post #2 of 131 (permalink) Old 06-17-2007, 08:58 PM Thread Starter
Re: AC not working need help
so basically its blowing out warm air even though I put the AC on the coldest setting.
Here is a video of the compressor click here
What are your thoughts?
thanks,
Andrew
00PSD1 is offline
post #3 of 131 (permalink) Old 06-17-2007, 09:13 PM
Was that with the AC on or off mine does the same thing when the AC is off thats why I ask Oh and my AC work fine.
2002 FORD F-250 CREW CAB 4X4 7.3 LITER POWERSTROKE DIESEL
DP TUNER F5 W/ STOCK,HI-IDLE,60 TOW,80 ECONO,100HP,140HP,SMOKE,
DiPricol OPTIX GAUGES BOOST,EGT,FULL SWEEP TRANS TEMP,
AFE STAGE 2 INTAKE,4" MBRP TURBO BACK EXHAUST WITH A 5" TIP,
DETROIT LOCKER,MAG-HYTEC DIFF COVER,LIMO TINT ON ALL WINDOWS,
2 VIAIR 480 COMPRESSORS,8 GALLON AIR TANK,NATHAN P3 TRAIN HORN
THEDIESELMAN is offline
post #4 of 131 (permalink) Old 06-17-2007, 09:16 PM Thread Starter
that was with it on...iirc correctly it did not do it while off.
On Edit I just noticed coolant unless their is another green liquid are engines use that was coming down from passenger side tire right in the wheel well to the ground
what do you think?
thanks,
Andrew
00PSD1 is offline
post #5 of 131 (permalink) Old 06-17-2007, 09:33 PM Thread Starter
Does anyone have a clue? Do these AC systems need to be recharged?
thanks,
Andrew
00PSD1 is offline
post #6 of 131 (permalink) Old 06-17-2007, 09:40 PM
Get a flashlite and see where the fluid is comming from. Does it look like antifreeze, or when it is on your fingers does it feel more oily
2000 F250 powerstroke diesel 4x4, 4 door, Lariat,
big injectors, 76mm turbo
Black 2006 F250 Crew cab short bed lariat 2wd stock 120 miles as of 4/17/07
thedieselkid is offline
post #7 of 131 (permalink) Old 06-17-2007, 09:41 PM
Sounds like you may have a broken line somewhere that leaked out the refrigerant. Most A/C systems now use a UV dye in the refrigerant to help locate leaks, and it appears green even without UV light, so it may be the oil/dye charge that you see leaking to the ground. Start looking at all the hoses/lines involving the A/C and see if any of the connections/hoses are wet with oil/dye, or get a hold of a UV light at night and check it.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
post #8 of 131 (permalink) Old 06-17-2007, 09:56 PM
Check your oil. J/K
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #9 of 131 (permalink) Old 06-17-2007, 10:36 PM
If your compressor is doing that while on and it won't blow cool air then you need to recharge your AC or check out your Hi and Low pressure switches. Also pop your hood and see if the fluid is coming from the accumulator because it is in that area and that might be where your problem is.
post #10 of 131 (permalink) Old 06-17-2007, 11:08 PM Thread Starter
Where are these Hi and Lo pressure switches? Where is the accumulator? What does it cost to recharge the AC?
How many lines are their for the AC system?
Also even when on the fan setting it blows warm air it used to blow ice cold air when on the cold setting [img]/ubbthreads/images/graemlins/shrug.gif[/img]
thanks,
Andrew
00PSD1 is offline
post #11 of 131 (permalink) Old 06-17-2007, 11:24 PM
Check your lines and you should see some pressure switches the accumulator is that big can in the corner on the pass side. The AC system has like 6 lines. My bet is it is your accumulator or by it.
post #12 of 131 (permalink) Old 06-17-2007, 11:25 PM Thread Starter
I looked at the hoses none of them had fluid leaking. Their are two hoses on the passenger side that go into the cab that i could move back in forth is that normal?
also their is no more green fluid leaking
thanks,
Andrew
00PSD1 is offline
post #13 of 131 (permalink) Old 06-17-2007, 11:28 PM
Oh and your truck wont blow cool air if the AC pump is not pumping, have a messed up switch/wire, or if it is low on R134a.
post #14 of 131 (permalink) Old 06-17-2007, 11:33 PM Thread Starter
Which component is the AC pump? How can I check if its low on R134a?
All the AC/Fan settings work except it doesnt blow cold air.
thanks,
Andrew
00PSD1 is offline
post #15 of 131 (permalink) Old 06-17-2007, 11:33 PM
Was that geen fluid oil or coolant if it was oil from the AC system it might not leak anymore out because the AC system doesn't have anymore pressure to push it out.
