General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
hey guys,
i have a 2000 ford f-250. the air conditioning will only come out the defrost. i thought the problem was the vacuum pump, after i had put a pump that my buddy had in his truck (it was electric) on, everything worked fine, including switches and everything else. so i went to the ford dealer today got the new vacuum pump, and air is still coming out of the defroster. the only other thing i think it could still be is what my friend called the boost canister, or vacuum booster. it was pressurized and didnt leak, but something rattled around inside, could this be my problem? this canister is just in front of the pump is 6 or 8 in heighth, same in length, and oval in shape. any suggestions?
thanks,
john
2000 F-250 ext cab long bed, white. straight pipe, boost tube, tymar intake, 10k mod,gutted ebpv, wicked wheel, fumoto valve Sirius Satelite Radio. More to come....
Check the vacuum hose coming out of the frame behind front tire's. The hose goes from the frame to the inside of the hub. The hose's tend to dry rot after awhile, and create a vacuum leak. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2002 F-250 Crew Cab 4x4 Short Bed, Lariat, (VDH2) 37.50x13.50x22 Kumho's, on 22x10 Gear Alloy Sprocket's,Dual Bilstein's,AFE Stage 2 W/ Pro Guard 7,Garret GTP38R Ball Bearing Turbo, Autometer Gauge's, S.S. Turbo back Dual Magnaflow S.S., Zoodad, DVD player and TV
I have the same year truck and I have the same problem. I have the manual hubs on mine. Do I still have vacuum lines going to the hubs or is that just for the auto hubs? My A/C switches itself to the defrost vents when outside temps are up and the truck is working hard (like pulling my trailer up a long steep hill). Can anyone post pictures of the various hoses and their locations? After I let my truck cool down for awhile the A/C begins working properly (usually).
2000 F-350 SRW,CC,LB,4x4,Auto trans., A-pillar gauges boost, tranny, pre-turbo pyro., Edge Evolution, back up lights, 5000# air lift air springs, Tru-cool max tranny cooler, 4" turbo back exhaust, "DIY" tymar, Toyo open country AT's, Monroe reflex shocks, Wicked Wheel, CCV mod, Sonnax/Tri-cumulator. T/C lock up switch. Tows 2005 31' Cardinal TT 12,000+ lbs.
My a/c blows out the defrosters when I put the 4x4 selector switch into 4high! I just put WARN premium hubs on mine and got rid of the ESOF but I have not capped off any lines as of yet. The front hubs are in FREE and I switch to 4HIGH in the cab and it starts blowing out the defroster (turning back to OFF and turning the a/c off and then a few minutes all goes back to normal). Again, it did this before the WARN replacements too! My ESOF failed and I did not need that system anyway and opted for what some considered much stronger hubs per this website? Wish I could figure out what is going on here!
The switching mechanism to go from defrost to the vents is vacuum controlled and it defaults to defrost with a decrease in vacuum. I had this problem on 96 Bronco and it was the vacuum check valve that had failed, turned out to be something like a $5 dollar part. The dry-rotted hose would be a good place to look as well. gcoutlaw- cap the lines and it will work fine.
Mine also blew air from defrost vents when I switched to 4x4 and it turned out to be the vacuum solenoid that is mounted to the passenger side firewall just behind battery. Very easy to replace and about 60 bucks from the dealer.
I have the same problem and am going to try to fix it this weekend. 2001 PSD 4x4 Ex
First I will try to find the leak. (everybody seems to agree this is the problem with the symtoms you described)
The hubs can be leaking: Pull off the air line to each hub and pressurize with a vacuum gage. If either hub cannot hold pressure then that is the problem. (anybody know how much pressure should be applied?)
Next check the hoses and then the vacuum solinoid on the firewall. Find and fix the leak and your 4 x 4 front hubs should operate and your ac vents as well. However, I am no expert, just a weekend driveway warrior! If the ac is not blowing cold then that is a different issue i think.
As stated initially, I thought it was the hubs so I put on some Warm Premium hubs that I know manually lock or unlock (read some other posts, did not know any better).
Now, with that being done, I have not capped off anything as of yet so I presume I should put a cap on the line inside the fender wells up front where the line connects to the tab mounted to the frame and where that hose goes down to the front axle? Capping this off would maybe help as I guess now I have nothing to pressurize given I just took off the stock hubs? I guess I should also put a cap down on the bottom of the hose where it connects to the axle if I remove that hose to make sure no water or debris gets in there too?
I guess if none of this works, I do the selinoid or whatever behind the firewall?
Yesterday I went to the Ford dealer to buy parts to try to fix this situation. I was planning on buying hubs, vacuum lines and vacuum solonoid. When I found out that my local dealer now charges a 20% restocking fee on all parts returned, I decided to take a look at the truck first.
Thank you Wrongway, as that was my problem. The old vacuum lines from the hub to the connection on the firewall were rotted out. Went to the auto parts store and bought 5ft of vacuum line (seems higher quality than stock) and installed new lines on both sides. (had some line left over)
