Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-19-2008, 12:07 PM   #1 (permalink)
Are all Duallys 4:10 rear?
A guy at work was telling me that all F-350 Duallys have a 4:10 rear end. Is this true?
Thanks!
Mine: 1998 Dodge Ram 3500, 12valve cummins,QC, 3:55, 5speed, Silver, #10 TST & AFC.
Hers: 1999 F-250 CC 4x4, Auto, silver, 3:73, Stock.
Dos_Patas is offline
Old 08-19-2008, 12:34 PM   #2 (permalink)
bockhold's Avatar
Send a message via AIM to bockhold
Might be. Its a dully thats made to pull weight.
Jarrod
NRA member
1997 F350 4door 2wd long bed white 7.3L Powerstroke, E4OD, C5 4:10LS diff 326K miles on org engine
and is being repaired
bockhold is offline
Old 08-19-2008, 01:14 PM   #3 (permalink)
Mark Kovalsky's Avatar
No, it is not true. Depending on model year a dually could have a 3.73, 4.10, or a 4.30.
Mark
Mark Kovalsky is online now
Old 08-19-2008, 03:20 PM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
What Mark said.
For all the dually pickups that are on topic in this forum, 3.73 open axle was standard since the first SuperDuty was produced in January, 1998 as an "early" '99 model. 4.10 with limited slip was available at extra cost. Because the 4.10 was the only way to get limited slip until recently, most duallys have the 4.10 limited-slip rear end.
Beginning in the middle of the 2005 model year, Ford made available the "Tow Boss" pkg which includes 4.30 rear end with limited slip.
So although most '99 through '07 F-350 DRWs with diesel engines probably have 4.10 rear ends, some have 3.73 and some have 4.30.
SmokeyWren is offline
Old 08-19-2008, 11:57 PM   #5 (permalink)
My truck has 3.73:1 and as Smokey says has open differential. Ordered mine in March '99 and took delivery in May '99. Order sheet offered 3.73, 4.10, and 4.30 with LS an option on the latter two ratios.
Never understood, nor got a good explanation why Ford did not offer LS in the 3.73. Instead of a $200 option, you'll spend more than $1000 to put an Auburn or Detroit in your Dana 80.
Can only assume some Cone Head MBA in Marketing or Product Planning decided LS wasn't needed with 3.73.
'99.5 F350 Crew DRW 7.3 6sp 4WD Lariat
'08 BMW M5 E60 6sp
'03 Subaru Forester 5sp (wife)
manioso is offline
Old 08-21-2008, 07:52 PM   #6 (permalink)
Seems a lot of the 3.73 SRW are limited slip. Mine is and at 80K or so it sitll works very well. Will hook up on dry pavement though I only tested this theory once. Pulling up the boat ramp one wheel will start to spin then both hook up and at times spin them both. Other times it will alternate slipping one then the other but eventually hook up both.
2003 7.3 F250 SD SRW Auto DIY intake 285/70 1.5" Leveling Kit TS Performance 75 HP Chip
TTBadDog is offline
Old 08-23-2008, 11:53 PM   #7 (permalink)
The SRW and DRW trucks use two completely different axles - I cant exactly remember the details so I hope someone more knowledgeable will step up to the plate. I think the SRW trucks use a FORD axle, while the DRW trucks use a Dana (or something along those lines).
2003 F-350 Lariat ~LE~ DRW 4x4 CC SWB...
··· 6.0L & Torqshift w/4.10 Ltd slip
··· Lund racerback, Line-X
··· Stainless wheel opening and rocker panel trim
··· SCT® XCal2© --Innovative
... ARP headstuds, high idle mod, fog light/high beam on DRL truck
... Magnaflow cat-back exhaust
----- --- BIG$HOW -------<Õ¿Õ¬
Bigshow is offline
Old 08-24-2008, 12:57 AM   #8 (permalink)
Ragdude's Avatar
my '96 is unfortunately a 4:10, freakin ridiculous running 2500 rpm @ 70 mph. I wish I would have bought the auto & 3:73's, or a 4 wheel drive with the 5 speed and 3:73's [then I could have a real low gear]. But what the heck, I have lived with it this long...
The engineer that designed this 5 speed hopefully was fired and is now living under a bridge somewhere.
Protect the 2nd Amendment!
It's the original homeland security act.
'96 F350,Dually,CC,5 spd.,stock.
'02 Ex,Limited,stock
B100 baby! Bring it home, to the American farmers!
Ragdude is offline
Old 08-24-2008, 08:39 PM   #9 (permalink)
bockhold's Avatar
My 97 has a srw and has the 4:10LS. My mpgs are pathetic.
Jarrod
NRA member
bockhold is offline
Old 08-25-2008, 01:00 PM   #10 (permalink)
I used to run 70 or 80 mph with my 4.10 ls automatic when I wasn't towing, but with fuel costs what they are now, I stick to 55 mph whether I am towing or not.
2001 F350 XLT 4X4, shift on the fly, 38 gal fuel tank, running boards, sliding rear window, black, crew cab, long bed, 4.10, automatic transmission, 11,500 gvwr, 20,000 gcwr, 7500 gvw, dual rear wheels, 7.3l turbo diesel, completely stock, 114,00 miles when purchased, now has 125,000 miles, repairs so far: starter, batteries, cps.
DonWarkentin is offline
