Amsoil gear lube for front and rear end, which one and what weight? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 08-10-2006, 12:19 PM Thread Starter
I am getting ready to order some Amsoil gear lube for my 99 F-250 and I have some questions...
(1) What weight for front and rear?
(2) What rear end do I have? I know it's a 3:73
(3) How much do I put in the front and rear?
(4) Do I need the friction modifier in my limited slip rear?
(5) Do I want the Severe gear or regular synthetic gear oil?
For the front, they list 75W-90 in both Severe and regular
synthetic
For the rear, they list 75W-140 Severe and 80W-140 regular
synthetic, Why the difference in weight?
Thanks for the help!
Daryl
Early 1999 F250 Super Duty CC,PSD,4wd,Dk Toreador Red,Med Prarie Tan Int,Nitto Terra Grapplers 315/75/16's,3:73 Gears,Automatic,X-Springs,Telescoping Mirrors,Off Road Pkg,Sonnax Valve And Tricumulator Springs,Dynomax 4"
stainless turbo back exhaust,Hypermax 330 Chip, XLE5, 05 front end, Severe duty air cleaner. EBV-less turbo pedistal and turbo outlet. ((XM))myfi hard wired to factory 6 disc stereo.
2004 E-350 Chateau 6.0 Auto (First one on TheDieselStop.com) Gold ash metallic, Medium pebble leather interior, 3:55 LS,Dual alts, Trailer tow mirrors.
SNOW4ME is offline
post #2 of 9 (permalink) Old 08-10-2006, 03:37 PM
SmokeyWren's Avatar
My Photos: (45)
Re: Amsoil gear lube for front and rear end, which one and what weight?
75w140 for the rear, 75w90 for the front.
Ford/Visteon built in the Sterling MI axle plant with 10.5" ring gear.
Rear end holds more than 3 quarts, so buy 4.
Front end of a '99 SRW pickup holds almost two quarts, so buy two.
Maybe, maybe not. AMSoil says: "AMSOIL gear oils are formulated with friction modifiers for limited slip differential applications. There is no need to add limited slip or additional additives."
But some users have said you still need some friction modifier in some - not all- PSD rear ends.
After you have it changed and drive a few miles, then find a big parking lot and do some figure eights with the steering wheel going from lock to lock. If you don't get any racket out of the rear end of the truck - caused by the rear axle locking and the rear tires bouncing as they drag around the curve, then you don't need any friction modifier. If you get the racket, then I'd add one ounce. Continue driving for a few miles, then testing with figure eights again, and then adding one ounce, until the racket goes away.
First I would contact Bob or Sheryl Riley at www.dieselsite.com and get their opinion. Since they have only the Series 2000 Gear Lube on their website, I'll bet that's the one you'll want. [img]/ubbthreads/images/graemlins/cool.gif[/img]
synthetic
Some folks don't know what Ford requires. 75w140 synthetic in the Ford rear end. 75w90 synthetic in the Dana front axle.
80w140 is for some other application. :
SmokeyWren is offline
post #3 of 9 (permalink) Old 08-10-2006, 08:10 PM
JRF
Scroll down to the synthetic gear lube recommendation chart on this page. It says for its first choice for light duty diesel trucks to use Severe Gear 75w-90(SVG) and 75w-140(SVO). This is how I made my decision on which one to use. Hope this helps.
02 F250 XLT CC SWB PSD 4x4, 4R100, AIC, Bedrug, FS-2500 oil bypass, Dieselsite Trans & Coolant filter, 203 T-Stat, Autometer Sport Comps, Silverline 5" stacks, Wicked Wheel, ATS Housing, DP Tuner, Sonnax/Tricumulator, Homemade Tymar, TTM, HX, PML Trans Pan & Diff covers, ITP Reg. Return, AIH, Dick Cepek FC II 285's
JRF is offline
post #4 of 9 (permalink) Old 08-11-2006, 06:43 AM
I will want to use the Severe Gear. The www.thedieselsite.com website must not be updated. AMSOIL has not made the series 2000 for a least a year. The Severe Gear replaced it. Yes, it has the friction modifiers in it already. You do not need to put that in. Any other questions, please post here and I will answer them.
2006 F350 6.0 Auto CC 4X4 DRW LB
White Lariat 4.10 LTD Slip
Line-X, Transfer flow 57 gallon
Firestone Airbags, Colibert Hitch,
Recon lights, Truxedo Cover Edge A2
2004 F350 6.0 auto cc 4x4 drw lb
oxford white
xlt sport pkg.
4.10 ltd slp
aux idl ctrl
hd suspension
tt mirrors power
moon roof
Transfer flow 57 gallon replacement tank
Cap
Line-x spray in
Firestone Airbags
Edge w/juice
Amsoil 15W40
swenny is offline
post #5 of 9 (permalink) Old 08-11-2006, 07:21 AM
I went with Amsoil, in my Y2K-X....
The front, and rear axel, plus the transfer case, seam to be holding up very well, even after years of service.....It did require "2" bottles of limited slip juice to solve the grabbing problem in the rear-dif....Other than that...it's still clear after 50K miles...
Unfortunately, I can't say the same thing about the tranny....
I'm ""NOT"" a 100% sure...""BUT"" I suspect that the 'friction' differential of the Amsoil product was instrumental in the destruction of my transmission.....
In other words..it slipped to much, and burnt up the clutches....
$4000 later, I'm using Schaffer oil.....NOT even Mobil 1, either....
Cuz they've gone and changed their formula also...
You gotta be careful with this stuff....
Fomoco, synthetic differential grease, is recommended by them....costs a lot, and ISN'T ANY GOOD.....>>PERIOD<<<
So the question I have is this???
>>>WHY DOES EXPERIENCE RUN SUCH AN EXPENSIVE SCHOOL???<<<<
XS_SUV
Graupp is offline
post #6 of 9 (permalink) Old 08-11-2006, 10:48 AM
If you used the Series 2000 gear lube in your Ex. then, yes you would have needed the Limited slip juice. AMSOIL has refourmulated the severe gear, and it has the limited slip juice in it.
oxford white
xlt sport pkg.
4.10 ltd slp
aux idl ctrl
hd suspension
tt mirrors power
moon roof
Cap
Line-x spray in
Firestone Airbags
Edge w/juice
Amsoil 15W40
swenny is offline
post #7 of 9 (permalink) Old 08-11-2006, 10:28 PM
I used severe gear and needed limited slip additive.
Dennis
'99.5 F250 4x4 SC 6 speed 3.73 LS, Magnaflow 4" exhaust, South Bend con-o clutch.
The_Dude is offline
post #8 of 9 (permalink) Old 08-14-2006, 09:12 AM
DIESELSITE's Avatar
We just haven't updated out Amsoil section in some time. Since Amsoil won't allow the prices to be posted or an online purchase, we just take care of the calls when they come in. I'll get to the update soon.
The Severe Gear has replaced the 2000 and no modifier is needed.
Bob
Bob Riley, Owner DieselSite.com
Proud Sponsor of TheDieselStop.com
GOT DIESEL? call us at 888-414-3457
DIESELSITE is offline
post #9 of 9 (permalink) Old 08-14-2006, 09:48 AM
it could be very possible you needed a different atf than what you
used, what did you use? universal ATF, I have had good luck using Amsoil super shift racing fluid in a few different applications,
also remember depending on which slush box you have slipping, is either failure of mechanical hydralic pressure loss or electronic hydralic pressuure loss.
E4OD or 4R100 or the newer 6.0 trans are all goverened by electronics
that do fail and cause mechanical failure.
dont be so quick to blame the fluid, but without all the fact's in you still could be right
1988 F250 dually All New 7.3 IDI, Banks Sidewinder.
C-6 with GearVendors overdrive 3.55 ring gear
Synthetic SAE 10W-30/SAE 30 Heavy-Duty Motor Oil,
Evans NPG coolant.
AMSOIL ATF in the transmission, AMSOIL gear oil in the diff.
20MPG city 25/28 hwy
IDIABUSE is offline
