Annoying front end, steering issues - Diesel Forum - TheDieselStop.com
Old 05-01-2009, 10:16 AM   #1 (permalink)
nctuso's Avatar
So the initial problem was major steering jerk when going over bumps and really sloppy steering play with vibrations at over 55 mph. Tie rods and steering box were shot so i replaced them and sloppyness and jerks went away. But vibrations are still there, not near as bad but still there, with a slightly off center steering wheel. I've noticed the steering dampener shock is leaking, so thats probably some of it.
After doing the above repairs should an alignment be done? Would bad alignment cause these issues?
Jacked up the truck and B-joints and wheel bearings all feel tight.
Along with the already ford-rough ride these are really annoying.
nctuso is offline
Old 05-01-2009, 10:32 AM   #2 (permalink)
padgett114's Avatar
The steering dampener shock will help out some, I run a dual shock set up. If the steering wheel is off then it sounds like you need an alignment. If the steer box and tie rods were going bad the last time you had it aligned the alignment could have been off some. I would also have your tires rebalanced.
2000 f350 powerstroke 4x4,voltant intake, wicked wheel,MBRP 4 inch exhaust, BTS 6 position chip,BTS valve body, 35" Goodyear MTR's, Autometer carbon fiber gauges,Boost Relief Valve +, air intake heater plug, Max AC Assist,
padgett114 is offline
Old 05-01-2009, 02:23 PM   #3 (permalink)
stevedunham's Avatar
My Photos: (6)
Also check the Trac Bar mounting nuts/bolts for any play. Any looseness on the Trac Bar mounts can cause lots of vibration/wobble issues...
** SMD '04 F250 SD King Ranch delivered 8/19/04 **
28% Tint, Leer 100XL Cap, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, MBRP Duals, 4.56's w/ F&R ARB's, original motor blown @ 31,000..! Dynatrac Dana 60 35 spline stubs kit, PIAA 520 ATPs, Xenon HID's, Powerslot Cryos/Hawk LTS, SCT X3, blown Turbo replaced with II 60FORDHY, 58V FICM PICS
stevedunham is offline
