Any one have a Wiring diagram for 2001 F250 (Ground Problem) - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-19-2006, 12:41 AM Thread Starter
I believe I have a ground problem with my truck. If I am correct the short would be related to a harness or group of wires that are causing these codes to be set during a KOER switch test.
The codes are P1670, P0703, P1536, P1780, P0565 through P0569.
The codes are EF signal, Brake switch A&B, Throttle switch B circuit malfunction, Parking brake applied fail Circuit, TCS circuit and a bunch of the Cruise signal malfunction codes.
I have checked the connections at the IDM and the PCM no burned wires or ends. Any one have a CD or DVD that shows if all these codes are related to a group of wires near the IDM or PCM?
Thanks, jim
2001,F250 4x4,Auto,CC,Lariat.
Asahel is offline
post #2 of 2 (permalink) Old 08-19-2006, 06:09 PM
JimTJr's Avatar
My Photos: (20)
Re: Any one have a Wiring diagram for 2001 F250 (Ground Problem)
Are you doing the "Switch" test correctly? If I am not mistaken, (And I have AE also) It seems to me there is a "Procedure" you need to do while doing this test. It will show fails if you dont do the "Hands On" part. (Maybe it is working each switch in a certain order?) Not sure.
One of the best places for information like the wireing diagram though is www.alldata.com Our local library subscribes to it for all makes and when you go in to look somthing up it only costs like 10c a copy!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
