Anybody removed all their door locks? - Page 2 - Diesel Forum - TheDieselStop.com
Old 02-11-2009, 04:13 PM   #16 (permalink)
They punched in under mine as well. Twice
They got me on the passenger side once and on the Driver side the other time. The Jimmie Jammer stopped the driver side entry.
I have disconnected the key mechanism from working. My door key holes do nothing. I did put an external connecting jumper cable set in so if my batteries die I will be able to connect jumper cables without popping the hood.
I now have code alarm with pager, GPS tracking with remote shutdown. Like you see on cops. Also the GPS device is tied in with my alarm and it will send me a TXT msg to my phone if it is going off.
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, Triple disk converter, whicked wheel, 203 t-stat, High pressure bypass, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom 86gal AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
Old 03-10-2009, 01:22 AM   #17 (permalink)
Supporting Member
andrewbalser's Avatar
That sounds pretty cool. I was thinking of doing something like that myself. The AAA courtesy truck that runs around town here has a 'special' set of jumper cables he gets out of a tool box, hooks up to the dead car, and plugs the other end right into a plug that is hidden somewhat in the grill of the F550. If I had to guess, the plug on the other end is probably somewhat similar or even the same as the battery charging plug for an electric forklift.
2003 RED F-250 Lariat FX4
SuperCab, Short Box, 6.0L, Torqueshift
"1991" Sun-Lite Pop/Up Slide-In Camper
DIY-Coolant Filter
137,000 as of 1/26/2012
3/19/11, Converted to (red) Delo ELC, new bottle & cap, all temps reading good, orig EGR & OIL coolers, probably thanks to the coolant filter, and previously frequently flushed Motorcrap Gold.
Keep on truckin
andrewbalser is offline
Old 03-10-2009, 08:11 PM   #18 (permalink)
Sounds about right. It looks like a golf cart plug or something. Like this, but 30 feet long
Wrangler NW - Jumper Cable Quick Connect, 3 ft, 2 gauge
Old 03-11-2009, 10:00 AM   #19 (permalink)
KD7CAO's Avatar
Check out Anderson Power Products. They are the inventor of the plug that allows the genderless reverse polarity protected connector. I built my own cable set using high strand count welding wire (2 Gauge) 30 foot long. I wanted to be able to jump a tractor if needed.
I typically purchase from Anderson Powerpole & SB Series Sets: Bags of housings and contacts in different sizes
I find their prices to be nearly unbeatable. I also use their 15,30,45 Amp series for my radios, lights, and other accessories. Ham Radio Operators have been using them since the late 90s. See this drawing if your wondering how to utilize them for your lower current devices.
Powerpole General Assembly Instructions
Red on the Right Tongue Up, Black on the Left Tongue Up (looking into the connector from the contact side).
Hope this helps!
Eric KD7CAO
Basics:
2000 Ford F-250 SD Lariat, 4x4, 7.3L Diesel, Auto, 3.73 Rear End
Accessories:
Superchips 1705 Tuner, 5" Super Flow Exhaust, Dual Stage Garrett Turbo, Magnum Force Intake System, Headache Rack, Toolbox, Goose Neck Hitch, Yaesu FT-8900r Quad Band, Icom IC-2820h with D*STAR, Maxtrac and TT3+, Spectra 900, Whelen 90 Watt Strobe Pack for Rear - 4 Strobes (1 each) Brake Lights and Backup Lights, Whelen 75 Watt Strobe Pack for Front - 4 Strobes (1 each) Headlights and CL Lamps, Code3PSE Mastercom 3892L4, Sho-Me Arrow Controller and home built arrow stick.
Wants:
Front End Replacement bumper/grille, Locomotive Horn, Air Bags (suspension)
See Me: http://map.findu.com/kd7cao-2
KD7CAO is offline
Old 03-11-2009, 11:07 PM   #20 (permalink)
Supporting Member
Looked at the pic in the link provided---bingo
DIY-Coolant Filter
Keep on truckin
Old 03-14-2009, 04:36 PM   #21 (permalink)
hottip's Avatar
I had my lock busted out 2X so I ordered a pair of rear door handles from a local boneyard and added jimmyjammers. Use the remote entry or keypad to get in now. I never used the key anyway.
2005 Lariat 6.0 LWB fourx4 3:73 Silver Metalic, Heated Captains chairs, Tow Command, Reverse Sensor, Intergrated Brake Control, Power Rear Window
MBRP Turbo back exhaust, Glasstite Canopy, billet grill, 145K+
Scan Gauge 2
Lucy - Wife
Bear - Flat Coated Retriever
2000 HD Road King
1998 Campion 542 Explorer fishing machine
I started out with nothing and still have most of it left....
hottip is offline
Old 04-01-2009, 06:19 PM   #22 (permalink)
twinbulls's Avatar
I had mine covered ..... My bodyshop guy did it as a Lets see if I can do it thing ... looks factory and NO key holes...
They (scumbags) tried to get into 2 of my fords and busted out the key hole....
Now my Harley truck has NO key hole... I still have to run that wire to the battery....
1999.5 F-250 Lariat SD CC SRW LB Loaded V10 auto 4x2 K&N FIPK,Poweraid spacer,muffler deleted,custom seat covers,wood dash kit,tinted windows.BFGs 285s. A-Pillar gauges Tranny temp,oil pres and water temp.Hypertech PP 111 with themostat 160 deg.
ARE Custom Top W/ladder rack,Added a center seat/armrest,Clear corner lenses,TT mirrors, Rancho RS 9000X with incab remote, A work truck you can valet. NRA Life member.
2004 F250 6.0 Harley Davidson 4x4 crewcab
2007 F350 V10 Tow truck with selfloader
2003 F 550 7.3 Crewcab Fith wheel hauler
My Truck
twinbulls is offline
Old 04-01-2009, 08:34 PM   #23 (permalink)
ZMANN's Avatar
The keypad can be opened decoded 20 minutes with a well known internet spreadsheet ,,mine still works but will activate the alarm if used
O6 King Ranch cc sb 4 inch lift ,35 Pro Comp,Helo’s Edge Insight CTS guage only , Auber EGT , o8 center console ,2x10 subs, xm satellite ,coolant filter,RSX 9000 shocks,dual bilstein steering stabilizers ,Viper , remote toolbox popper, High Idle mod , up fitters added ,weather guard mats , ARP's, BPD EGR cooler, Marinco Mod ,Zoodad waste Fabtech traction bars, Some other stuff
ZMANN is offline
