Anyone know the fuel pressure coming from the in-take pump on an 02' F-450? - Diesel Forum - TheDieselStop.com
Old 11-11-2012, 12:08 AM   #1 (permalink)
My co-worker has a 2002 F-450 diesel. He's already had to replace the aft-axle tank, and later on he had to replace the in-tank fuel pump.
He's looking to add a Racor spin-on filter/seperator before the frame rail pump, but since the Racor is designed for vacuum only, I cautioned him about the pressure coming from the in-tank pump.
If the in-tank pump is pushing only a few psi, then he might not worry about it. If it's pushing 35 or so, then it increases the likelyhood of the filter weeping fuel.
Just curious if anyone knows the pressure the in-tank pump is designed to push to the frame-rail pump.
Thanx in advance......
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump.
txgp17 is offline   Reply With Quote
Old 11-11-2012, 12:30 AM   #2 (permalink)
klhansen's Avatar
My Photos: (175)
If it's' a diesel, there's only the frame rail mounted pump.
The in-tank gizmo is a thermostatic mixer for return fuel, not a pump. If he puts the Racor on the suction side of the frame rail pump, it'll work fine.
Hard or no-start? Check Here
Old 11-12-2012, 10:32 AM   #3 (permalink)
Why do the aft tank trucks have that compared to the forward tank trucks?
Does the metal versus poly tank have anything to do with it?
Old 11-12-2012, 08:22 PM   #4 (permalink)
klhansen's Avatar
My Photos: (175)
All the diesels, no matter where the tank is mounted just have the mixer inside the tank and a frame mounted fuel pump.
