General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Hey, I know this is a very random question, but yesterday I bought a 10x4 cowboy up die-cut decal for my truck with a whole bunch of little details in it and when I went to put it on a few minutes ago I started to peel the wax paper off all of the sticker stuck to it. Is there some sort of way or technique to take off the wax paper w/o it sticking?
Thanks,
Scott
FOR SALE
2002 F350 CCLB 4x4 Off Road
8" Donahoe Lift, Dual Bilstein 5150 Shocks frt singles in back, Skyjacker Dual Stabilizers, 37x13.50R17 Toyo M/T's on 17" MB Razors, 5" BH Stacks, DP Tuner, Tymar Intake (True Tymar), Autometer Phantom Boost and Trans & Banks Pyro,BTS Valve Body Truck Pictures
You might beable to apply some soapy water and squeegie the sticker on. Get all the bubbles out of it...Then wait for it to dry...might beable to use a hairdryer and then peal it off.
But make sure the paint is clean...so might want to clean up the surface with alcohol??
good luck,
Steven
01 F350 CC LB 4x4 SRW,(w/forged rods), 6" Lift, 37"ToyoMT, 22"MKW M19's, Mini Mes, GTP38R, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Truspeed, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, ITP Boost fooler, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
4/8/08 402hp, 824 ft-lbs Mustang Dyno
8/2/08 14.39 in the 1/4 @ 93.5mph on 37's @ 8950 lbs
If there is wax paper, the sticker, and then a mask, then you can lay the sticker face down, hold the mask with one hand and fold over the wax paper and slowly peel it off with your other hand. Since the front of the sticker(the non sticky side) will be stuck to the mask, make sure you keep it flat on the table while peeling the wax paper. If the wax paper tears, use and an exacto to pull the remaining paper off the sticky side of the sticker. Does this make sense? It is so much easier to show someone in person than in an e-mail. I hope this helps, let me know...
__________________ 2002 F350, 4 door, short bed, 7.3, 12" lift, 38" Mickey's, Fabtech Trac bars, AFE intake, DP Tuner w/custom tunes, Terminator dual HPOP's, 4" MBRP cool duals, Pyro, Boost, Transmission, and Differential guages, and custom 14" drop hitch with hiem joint supports
Use a old credit card or something somewhat stiff but plyable to squeegee over the masking part (face of the decal). This should make it stick better to the masking. If that does not work, lay the decal on it's back (on the masking side) and slowly peel the wax paper side off from one corner while keeping it as low as possible.
