ATF transmission fluid as fuel additive??? - Diesel Forum - TheDieselStop.com
Old 10-29-2009, 10:36 PM   #1 (permalink)
I was recently told, by someone that I know knows diesels but also lies about stupid stuff to make himself seem better for some reason, that by adding a quart of atf transmission fluid to the fuel tank every other fill up will help keep fuel lines, injectors, etc., good and protected while boosting performance a bit. I am not doing it until I hear from a few others that they have done it or heard of it. So please let me know if this is as ridiculous as it sounds or actually true. Thanks so much. By the way I have a 2005 F-350 with the 6.0L.
Last edited by ocwrestler160@yahoo.com; 10-29-2009 at 10:44 PM. Reason: forgot info
ocwrestler160@yahoo.com is offline
Old 10-29-2009, 11:19 PM   #2 (permalink)
If you are using ULSD and/or winter fuel you should add lubricant to every fill-up. ATF is ok but 2 stroke oil mixes easier. Better yet are diesel additives with lube & cetane booster such as Stanadyne Performance Formula.
If adding oil the mixture ratio is 1% In USA that's about 1qt to 25 gal.
Evel486 is offline
Old 10-30-2009, 12:33 AM   #3 (permalink)
Smiley1's Avatar
NOOOOOOOOOOOOOOOOOOOO!!!!!
That is very bad. Trans fluids are not what they used to be. Nor are the fuel systems of today.
Look here: Fuel Addative Lubricity Study
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
Old 10-30-2009, 02:07 AM   #4 (permalink)
well after reading your thread it would make sense to add some form of lubricity and why not tranny fluid, specificaly. I know you wrote it isnt what it used to be but what COULD it do?? thanks for the help by the way.
Old 10-30-2009, 07:21 AM   #5 (permalink)
FTG-05's Avatar
My Photos: (25)
Two things: today's diesels aren't what they were years ago when adding ATF was the smart thing to do. Secondly, today's ATF isn't what it was years ago either. ATF is not meant to be burnt in today's diesel engines.
Any additive you add to diesel fuel needs to not have ash in it. 2 cycle oil is one as are the various cetane and lubricity additives on the market specifically for diesels.
With all the options out there that are effective and benign to today's diesel engines, ATF should be low on the list of additives, if on the list at all.
My .02.
Al
P.S. I add a couple ounces of 2 cycle oil to fuel when refueling, FWIW.
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 10-30-2009, 10:08 AM   #6 (permalink)
Smiley1's Avatar
I run the ashless 2 stroke oil as well. 1oz per gallon. Works great.
Smiley1 is offline
Old 10-30-2009, 12:37 PM   #7 (permalink)
OK perfect people thankyou so much
Old 10-30-2009, 01:55 PM   #8 (permalink)
Matt0987's Avatar
I use Stanadyne. It makes a major difference in the volume of the engine, the response, as well as how smoothly it runs.
1 oz does 5? gallons?
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 10-30-2009, 02:00 PM   #9 (permalink)
chuckster57's Avatar
My friend has a 2005 GMC 2500HD with the 6.6 duramax. He is having injector issues and two different places told him to run the Stanadyne fuel treatment to see if it clears up. I will let you know if it works, if not then we have to change them (YUCK). Must be good stuff.
FWIW I have used P/S Diesel Kleen ( silver bottle) in every tank since I got this truck.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 10-30-2009, 06:25 PM   #10 (permalink)
ALR1955's Avatar
Send a message via AIM to ALR1955
I use the Amsoil diesel fuel additive and Cetane Booster all the time and my engine runs so much better!! You can hear the difference after just a few miles after I add it to the tank.
2006 F350 Lariat SDSC 4X4 DRW
4" Lift system w/ airbag leveler system
Bilstein 5150 shocks
Ameritrac LT235/80R17 tires
Banks turbo back 4" Monster exhaust system
AirAide Intake Filter
Accufab Polished Intake tube
AgriCover Bed cover
Romik SS Grill/Brush guard w/ PIAA Driving Lights
Kenwood 5120 Series Entertainment/Navigation system
Kenwood Sirius/XM Satellite Radio system
ALR1955 is offline
Old 11-05-2009, 11:56 AM   #11 (permalink)
What about Lucas Oil, has anyone used it? I was also told to use Seafoam. I have used both of these, but really can't tell any difference. Mileage is the same, and seems to run like it alwasys did.
2002 F 350 4x4 Crew Cab Lariat
7.3 Diesel 6-speed manual
206,000 miles
All Stock, Possible Chip?
schoolde is offline
Old 11-05-2009, 08:21 PM   #12 (permalink)
BlueMuleTrucking's Avatar
Send a message via AIM to BlueMuleTrucking
I use Power service with cetane boost almost every tank year round.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline
