Attempted theft of my '04 - is the ignition key chipped? - Page 3 - Diesel Forum - TheDieselStop.com
Old 03-03-2005, 07:53 PM   #31 (permalink)
whotnow's Avatar
My Photos: (13)
Re: Attempted theft of my '04 - is the ignition key chipped?
If there is no pats system, and the key is just the ornamental pats key (the one with the blue oval), why would they not be able to replace the key with a regular one?
-Rich
They can be replaced with a regular key, Infact i keep one of the $.99 jobies in my wallet just in case. BTW it starts and runs the truck with no problem. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
FOKISD Charter Member from Chillicothe, OHIO
2004 Excursion, Auto, 4X4, 6.0 Turbo diesel, Harley Instument Cluster, Heavy duty Headlight harness w/Fog Lights mod, 26/24 inch wipers, 3.73LS, X and F w/350 blocks/spring upgrade, XMradio, Grill and tail light guards, Sunvisor w/marker lights, rear spoiler, 2 JL audio 12's, Front Marker Mod, rear swaybar, Hella Highbeams mounted on grill guard, Air rite Airbags, Born On 12-03
2002 F550, Auto, 4x4, 7.3 turbo Diesel, Altec Boom, utilitybed, Ex-Allegheny Power Truck.
whotnow is offline
Old 03-04-2005, 04:44 PM   #32 (permalink)
I installed a Cyclops Anti Theft relay in mine. The truck will not start without the pushbutton key fob or the other activator that plugs into the 12v outlet.
This relay replaces the injector relay in the fuse panel. With this no one will drive it away. If someone wants it bad enough they could probably hoist it on a flatbed, at least they won't just drive it away.
Ahhh, a very interesting device. I like it. I assume the owner would keep the regular relay on hand in case the cyclops would fail for any reason to operate..
Going on a long trip this summer to unfamiliar states. I think this would be a good investment.. Thanks for the link..
Best to you.
2011 F-350 DRW, PSD, CC, LB Lariat w/bed cover and factory Reese 5er hitch..
2006 Cherokee Lite 285B+S 5er
2009 HD Ultra Classic, red/gold
2007 HD FXD Super Glide, Red
LeeChristianson is offline
