Auxillary Idle Controller - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 12-19-2007, 11:03 AM Thread Starter
My Auxillary idle controller decided not to work all of a sudden, who fixes them or what can i do besides buy a new one ?
1999 F-250 4X4,crew cab lariat,Fun Fast
, Lots of stuff, 175,000 mi and runs better than ever.
2008 SD crew cab F-250 Lariat, " Here we go again"
Dieselholic is offline
post #2 of 14 (permalink) Old 12-19-2007, 11:20 AM
SmokeyWren's Avatar
My Photos: (45)
Re: Auxillary Idle Controller
Your Ford AIC is actually a small computer. The name of the black box is auxiliary powertrain control module (Aux. PCM). So like most small computers, when it goes south you throw it away and buy a new one.
SmokeyWren is offline
post #3 of 14 (permalink) Old 12-20-2007, 01:06 PM
does it light up?
check the connections look for fuses pulled wires etc...
it sits where it can get kicked so that would be my guess.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
post #4 of 14 (permalink) Old 12-21-2007, 12:46 PM Thread Starter
Southmike, Yes it lights up and when i drive it the RPM'S work, its just when i try and use the Volt controller or the Manual RPM it dosesnt work.
post #5 of 14 (permalink) Old 12-21-2007, 12:47 PM
My Photos: (6)
Do you have the parking brake on?
, Auto, Dark Green Satin, Med. flint, Heated captains, ESOF, Remote start, AIC w/ wood grain cover, Chrome cab steps, Reciever hitch, Power rear slider, Clearance lights, Rubber mats, Rhino, Extang bed cover,
, PIE
'05 Isuzu NPR flatbed dump
'04 Isuzu NPR diesel flatbed dump
'90 F350 box dump
Kubota L4240 HST (Front loader, Harley rake, Rototiller, Brillion Seeder, pulverizer) , Perma Green Centri (ride on spreader), Walker Mowers (the best), Shindaiwa and Stihl
Toys:
36' Pacemaker Sportfish
'90 Mustang GT 5.0
'90 Jeep Wrangler 4.2
'72 Triumph Spitfire
15' Boston Whaler 70hp Yamaha
Yamaha GP760
Sunfish
1Chavez is offline
post #6 of 14 (permalink) Old 12-21-2007, 01:06 PM Thread Starter
Yes, parking brake is on.
post #7 of 14 (permalink) Old 12-21-2007, 01:24 PM
My Photos: (6)
Does the P-brake light on the dash come on? Just thinking that maybe the switch that says p-brake is on is not sending the signal to the AIC.
, PIE
'90 F350 box dump
Toys:
'90 Mustang GT 5.0
Yamaha GP760
Sunfish
1Chavez is offline
post #8 of 14 (permalink) Old 12-21-2007, 02:51 PM
Kanman's Avatar
You might check to make sure your alternator is functioning correctly. Are you having any other problems with the truck?
Kanman is offline
post #9 of 14 (permalink) Old 12-21-2007, 06:11 PM Thread Starter
1Chavez, I will check that, i never noticed the light coming on before.
Kanman, I have the alternators guaged, everything checks ok. I have minor stuff wrong, like the pass door auto lock dosent work , i need a new turn signal, with the winshield wiper on it. It comes on when it wants. Thats about it.
I checked through the manual i will double check and let you know. Thanks for the info guys !!!
Bud
post #10 of 14 (permalink) Old 12-31-2007, 05:40 PM
Dieselholic, if you need another one, I have the one from my '01 works fine, took it off before I traded on an '08. email me if you need it, I'll sell it alot cheaper than new one.
Chris
2012 F550XL 19,500gvw, Oxford White/Steel interior, 6.7psd, Stainless simuators, Sync, 16Ft Morgan body, Waltco tuckaway 2500 lift gate.
2011 F250 CC Lariat Ultimate, Royal Red/Pale Adobe, 18" wheels, 3.31 locker, 172"WB factory Nav/Sync,etc.
Also have a 1997 F450 7.3 XLT with 14' box, Hypertech programmer
1987 F350 6.9 Banks Sidewinder, 12' box
Still going at 200K+
Traded:08 F250 CC 4x4 Lariat, 172"WB
Traded:01 F350 CC 4x4 Lariat, 172"WB
SCORPIO26 is offline
post #11 of 14 (permalink) Old 01-01-2008, 09:44 PM
hey what do these run for a new one. thanks john
2003 crew cab dually xlt 4x4 7.3 6 spd std tranfercase black w/ grey interior
6637 filter, 5 " mbrp straight pipe,wicked wheel,ebpv delete pedistal, high flow outlet housing, dp tuner(no start ,stock,1100 high idle,20 40 60 80 tow, 80 econo, 100 perf.) ih bellowed up pipes, coolant filter, isspro ev2 pyro and boost gauge, aih delete and a snap on screwdriver handle for my shifter handle
2003 excursion limited ultimate 7.3 black w/ tan
every available option bone stock
ihdieselnut is offline
post #12 of 14 (permalink) Old 01-02-2008, 09:42 AM
When I got mine it was like $375.00 via the net. Local ford dealer wanted like $600.00 for one.
post #13 of 14 (permalink) Old 01-06-2008, 09:19 AM Thread Starter
Chavez1 , Ive been away during the holidays, You mentioned that my parking brake light should come on when engaged, well i checked it and it doesnt, could this be why my AIC dosent work ? How do get the light to come on ? I understand its possible its not sending a signal to the AIC if not fuctioning. Hope everyone had a safe and nice hoilday !!!! Thanks
Bud
Scorpio, I may be in touch , have to wait and see.
post #14 of 14 (permalink) Old 01-06-2008, 07:07 PM
Sounds like you may have a bad parking brake switch, possibly a bad/loose connection at that switch. Check that area first.
