General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
What are ya all usin for batteries? I have 88.7k on the ticker and the stock batteries are starting to fade. I was thinking of optimas, but I remember a post on here a while back saying they don't hold up to heat. Inputs would be great.
2003 F-350 6.0 CC LB SRW, 4" MBRP turbo back, 315/75/16 Cooper Discovery S/T, 30' Mckenzie TT
Both of my original's Crapped out at 26K,the dealer replaced them under warranty with More Motorcraft's (Of course) My last truck a 98 F150,the Motorcraft lasted 5 years & never did die,I finally replaced it because I felt I was on borrowed time.
__________________ 2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
The F150 I replaced with a Sears Die Hard,it was still in the truck when I traded it for my 05.
If you go to Optima's web site there is not an option to see what batteries a diesel needs. That to me is saying that they will not hold up to a diesel.
__________________ 2002 F250 7.3 4X4 Super Crew Short Bed. Gauges, Super Chips, Muffler Delete, 05 Factory Tow Mirrors, Custom Upfitter Switches, 285/75 R 16's, Ambulance air compressor, 24" Grover Air Horn, AIC, Commando Alarm with remote start, & Turbo Timer . Pullin' a 2006 Puma RBS 249 5er and a 2000 Fisher Marsh Hawk Bass Boat.
DW like's the diesel so much I had to buy her one.
The "Baby Diesel" 2004 VW Jetta TDI. It's nice but it ain't my truck
They hold up fine in a diesel. I have had mine for 3 years now with no problems. If I only needed replacement batteries for my stock truck with no large qty of aftermarket lights, winch, 12V compressor or demanding audio, I would just get the Motorcraft 850's. They have the same warranty as the Optima Red Tops, more CCA amps than the Red Tops and are much cheaper. I believe you can get them from Autozone or O'Reileys (I cannot remember) for $80 each.
QtrHorse, what would you use if you had a winch or other accessories. I don't have any yet, with "yet" being the key word. I called the dealer and the 850CCA Motorcraft are $115 each.
2002 f250 7.3L psd crew cab 4x4 dark shadow gray with custom pearl silver flames with purple tips pinstriped in burple.rubicon express 6.5" lift with 37x13.50r17 toyo mt tires.AFE stage1 intake, magnflow ss 3.5"-4"exhaust custom 4" ss flame tip,autometer z series pyro,boost,trans temp gauges ,trenzs flame pedals,rv mirror,superchips 1705,ARE Z series cap w/wing,centerline 17x10 cooler wheels,Kenwood HU w/ kenwood graphic EQ mounted in the dash, Kicker 3-way components up front, kicker compontents in rear, w 2 kicker 10" L5 subs powered by kicker KX650.4 & KX850.2 amps Kicke kx3 crossover ,Kenwood 10 disc cd changer,all wired with stinger wire/ blocks/fuses,
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: iachild</div><div class="ubbcode-body">QtrHorse, what would you use if you had a winch or other accessories. I don't have any yet, with "yet" being the key word. I called the dealer and the 850CCA Motorcraft are $115 each. </div></div>
If I were going to use any high amp draw item, I would get The 750 CCA Red Top Optims, the big Yellow tops, big Odyssey or a big Powermaster battery. They all do well when it comes to being drained and recharged and most of them will have longer reserve times than the wet cells.
Read my post again, it was either Auto Zone or O'Reileys that had them for $80 or $90. When I priced them at the dealer, they wanted $125.
