which battery to jump start? - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 08-05-2006, 01:34 PM Thread Starter
My Photos: (12)
Which battery should be used to jump start my truck? I've never jumped it. Jumped plenty of vehicles with my truck, but never the other way around!
2002 Silver F350/4WD/PSD/CC/LWB/SRW
4" Turbo back ATS Exhaust/DI Flip Chip
185k and counting
granitehauler is offline
post #2 of 15 (permalink) Old 08-05-2006, 01:36 PM
Re: which battery to jump start?
I have always used the one with the cable that goes to the starter, and ive never had any problems..
69camino is offline
post #3 of 15 (permalink) Old 08-05-2006, 01:38 PM
svsoccerpoker's Avatar
It should not matter they are both connected in paralell.Either one will work. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2006 F-350 King Ranch 6.0L V-8 Diesel - 4X4
4.5" Donahoe Racing Lift Kit w/ 35" Dick Cepek
Banks Power Monster Exhaust
Banks Power Diesel Tuner
Banks Power Speed Loader and power PDA tuner
Two 7" Warn Lights
Front end replacement bumper w/ grille guard
9.5ti Thermometric Warn Winch
Two 5' Black CB Whips installed inbetween cab/bed
Uniden CB Radio (Bearcat Style)
JL Audio 13W7
JL Audio 1000/1 Amp
Stinger 40 Farad Cap.
svsoccerpoker is offline
post #4 of 15 (permalink) Old 08-05-2006, 04:36 PM
My Photos: (6)
I'm not sure about the current engines. But I know on the 6.9, and I'm pretty sure on the 7.3, they were explicit in the owner's manual about always jumping off the passenger side battery. I'm not sure why. I'll use the passenger side if I ever have to jump off my truck.
DieselDennis is offline
post #5 of 15 (permalink) Old 08-05-2006, 09:06 PM
The reason you are told to jump off the passenger side battery is that if you are on a public street, it keeps you the furthest away from traffic.
The batteries are connected in parallel, so it makes no difference which one you use.
2000 F-350,XLT,L/B CREW,4x4,Auto EOD 3.73,ESOF,SCMT,Dual Alt.,
PTOed with the switch,Line-X,Weather Guard Box,Oxford/Silver.
Tripple A-Pillar/ISSPro,TTM,2x4 low,Rancho 9000s/5404 SS, Jardine 4"
, Dynomax, Tuff Country leveling kit, (UKN1),
rlarkin is offline
post #6 of 15 (permalink) Old 08-05-2006, 09:21 PM
The real reason is the battery cable to left batt. is a
smaller gauge. Resulting in a bit of a voltage drop.
01'f-350
dzl wannabe is offline
post #7 of 15 (permalink) Old 08-05-2006, 10:18 PM
haul_n_horses2's Avatar
My Photos: (17)
[/ QUOTE ]I thought the real reason was that the wire to the starter comes off the + terminal on the passenger side battery. Hence the shortest run of wire to the starter.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #8 of 15 (permalink) Old 08-06-2006, 02:24 AM
Same difference. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
What would be the advantage of a shorter distance? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Less voltage drop from series resistance <lenght of wire being heated>
Wire that is heated constitutes a series load which will show a voltage drop equal to the value of the resistance to the load placed on cable. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
99 F450 PSD FWD 4:88 final drive Detroit Locker on the rear 16' aluminum bed Ezyloader 16' articulated hive crane. Otherwise BONE STOCK!
miteyvictor is offline
post #9 of 15 (permalink) Old 08-06-2006, 04:25 PM Thread Starter
My Photos: (12)
Thanks guys.
I have something draining my battery. Had it on the trickle charger for a day and that kept it charged for about 3-4 days. Now to track down the drain!
185k and counting
post #10 of 15 (permalink) Old 08-07-2006, 04:49 PM
When my converter shorted internally and drained my battries [img]/ubbthreads/images/graemlins/blush.gif[/img](in the outback of West Texas) I needed to run cables to both batteries to produce the current needed to crank the motor. Granted they were smaller cables and the batteries were DEAD not just low but one set to one battery would just not do the job. I now carry two sets. A huge thanks to the Texan with the ford diesel that came by and stopped to help and carried two sets. [img]/ubbthreads/images/graemlins/smile.gif[/img]
2004 F350 Lariat CC LB FX4 Auto, camper package, superhitch, rear susp air bags, Rancho 9000 shocks, 800W/1600W 115v power converter, Ultralite gauges in overhead 4 gauge pod, 04/04 build and engine Reman shortblock at 34,000 Due to oil leaks, MBRP turbo back, SCT extreme street by ID
10.5' camper, 20.5" Bayliner Cuddy 5.0 V8
1999 Kawasaki ZRX1100
rubystargoats is offline
post #11 of 15 (permalink) Old 08-07-2006, 07:25 PM Thread Starter
My Photos: (12)
Well, it ended up being the alternator. Now we're back on the road. The batteries were low enough that the stereo would go in and out and the abs light showed up. Lots of wierd things happen when the batteries get low!
185k and counting
post #12 of 15 (permalink) Old 08-12-2006, 05:21 AM
artherd's Avatar
"Lots of wierd things happen when the batteries get low! "
That's no joke! If you think our trucks are bad when an alt and then battery goes though, try my 1988 bmw 750iL. All dash lights going crazy, and the engine thinks it's got half failed and only runs on 6-cyl.
- 99 F350 CC, LB, Dually - 01/98 Production Date - Tommy Gate hydraulic liftgate (awesome & highly recommended.)
- 19.5" Goodyear G622s on F550 wheels front and rear.
- F550 brakes. 1050CFM thermostatic 2nd tranny cooler. Prodigy brake controller.
- 4" exhaust to the turbo. 4-pillar EGT, TRANS, WATER, BOOST.
- Ford Ambulance APCM/AIC. Severe Duty AIS.
- Code 3 2100 LED Lightbar, Perimiter Strobes, LED-X lights, Electric (firetruck type) warning horn & PA.
- 4 batteries, Xantrex 250A automatic battery combiner/splitter.
- Dual Xantrex Prosine 2.0KW inverters for 110/220v, Laser printer/copier, plasma cutter, welder.
artherd is offline
post #13 of 15 (permalink) Old 08-12-2006, 11:36 AM
Neither, jump starting can kill electronics. Not at the time of the jump start, but that is when the damage is done. Then a few years down the road the damaged trace on the pc board fails.
Electronics don't like voltage spikes and you get a hell of a voltage spike when you remove those jumper cables, beleive me.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103
Wayne B is offline
post #14 of 15 (permalink) Old 08-12-2006, 12:02 PM Thread Starter
My Photos: (12)
Wayne B
So how do you get a dead-in-the water 8000 lb truck off your driveway and to the shop besides towing it? [img]/ubbthreads/images/graemlins/shrug.gif[/img] I agree that it's not the best alternative, but what else can be done? (I'm not being a needler, I'm actually really curious!) I always make sure the ventilation fans are on as I've heard that helps when jump starting.
185k and counting
post #15 of 15 (permalink) Old 08-12-2006, 04:29 PM
Here is a trick I learned when I used to drive a wrecker for AAA.
Have the person in the vehicle being jumped turn their headlights on as soon as the vehicle starts. This will help the voltage regulator from sending a large spike to the vehicle's electrical system.
Just my 2 cents.
Marc
2015 F 250 Supercab 4x4 Lariat long bed. Whelen M7's in grille, Whelen Inner Edge, Whelen custom interior rear lightbar/traffic advisor, Whelen Cencom Saphire controller, and other hidden emergency lighting, UWS cross box and custom bed cover
VTFireftr is offline
