Best batteries for F350 - Diesel Forum - TheDieselStop.com
Old 01-01-2013, 08:47 PM   #1 (permalink)
Question Best batteries for F350
Hi. Looking for some information and any information would be greatly appreciated.
We will soon need to replace the batteries on our 6.0L V8 diesel F350. The ones we have are the original ones from when we bought the truck new in 2006 (we think that is good going compared to the lifespan of batteries we had in the past on smaller vehicles). Just putting out feelers to see what other makes of batteries you prefer/recommend for these harsh Canadian winters.
Helen R is offline   Reply With Quote
Old 01-01-2013, 09:28 PM   #2 (permalink)
I don't know what is available in Canada but if you were in Tulsa Oklahoma I would tell you that a Sears Die Hard Platinum is the best battery available.
444-4D is offline   Reply With Quote
Old 01-02-2013, 11:15 AM   #3 (permalink)
Homegrown's Avatar
Most of the Wal-Mart batteries are made by Johnson Controls, who have been making great batteries for years. I run them in my truck, tractor, boat, and lawn tractor. I've been very happy with them. But it will be hard to beat the 10 years I got out of the OEM Motorcraft battery in my truck - it still tested OK, but 10 years on a battery is borrowed time.
FOKISD Charter Member from Hillsboro, OHIO
'01 F-350, XL, SC, LWB, V-10, 4R100, 3.73 LS, High Back Buckets, TT Mirrors, Roof Lights, Camper Package - Check my Photo Gallery for modifications. Michelin LTX M/S 2's on Mickey Thompson Classic II's, A.R.E. DCU cap, Reese Titan V and Draw-Tite front reciever, Audiovox cruise control, Wolf center console, Truck-Lite rear ID bar, Hella FF75 driving lights. Bilsteins on each corner.
Homegrown is offline   Reply With Quote
Old 01-02-2013, 02:24 PM   #4 (permalink)
Thumbs up
try x 2 batteries there kinda spendy and worth every penny there way better than optima and even have brass terminals i was going through a set every year or so until i bought these batteries they even have a five year free replacement
brianmilespeterson is offline   Reply With Quote
Old 01-02-2013, 07:43 PM   #5 (permalink)
This.
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump.
txgp17 is offline   Reply With Quote
Old 01-03-2013, 08:41 AM   #6 (permalink)
My Photos: (19)
Since you have the 6.0L it's a different animal than my 7.3L. I get 3 years on a set of batteries. Used Motorcraft for the first two sets. Then I found someone that carried Exide. Those seemed to last a little longer, so when I had to replace them yesterday I bought Exide again. Since they cost about the same as the Interstate I may try those next time. I just can't bring myself to buy a walmart or even an autozone/o'reily battery.
DP-Tuner 80T, Stage I single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is online now   Reply With Quote
Old 01-03-2013, 09:57 AM   #7 (permalink)
sd73man44's Avatar
Smile My last batteries are glass mat
My '99 7.3l is on the third set of batteries, and the last set are the Sear Glass Mat. I like them because they don't corrode like the flooded batteries. About $200 ea at Sears. The only thing I have heard is they don't like to be over charged. So make sure your system is working properly. I have also went to a constant current smart charger to replace my older constant voltage charger.
They are sealed and have what's called "no spillable acid" so they do not corrode the post connections as the wet cell batteries do making a mess to cleanup on occasion.
'99 7.3L SD F250 4X4 manual 6 speed - original.
sd73man44 is offline   Reply With Quote
