big problem! - Diesel Forum - TheDieselStop.com
Old 12-30-2012, 11:03 AM   #1 (permalink)
big problem!
I am having an issue with my lights or my charging system. When i turn my lights on only the head lights come on. No dash lights, No marker or park lights. and when ever i run the lights it kills the battries. I've changed the headlight switch and relays. I've checked the wiring and everything is tight. Battries are good and altanator is charging. I can't figure it out. If anyone has any ideas please let me know. It's a '99 F350 Diesel 7.3
Tanker78 is offline   Reply With Quote
Old 12-30-2012, 11:34 AM   #2 (permalink)
My Photos: (28)
If you know the alternator is good, and your batteries have been stress tested, my guess is that you have a bad ground somewhere. Follow the black leads of your batteries from top to where they connect and make sure there cracks or breaks in them, and the connection is solid. If you suspect anything, change them out. You may want to remove them and take a wire brush to both ends before re installing them. Another thing to do is check both fuse boxes (under dash and under hood)...look for any blown fuses, also check for any indication of electrical arching between fuses. I bought my '99 recently and the previous owner had installed six exterior lighting systems (all separately installed and not linked)as well as other things and the fuse box is really interesting now ;-) Hope those two things can help some...
'99 F350 XLT, SC, LB, 4x4, auto, 4.10 rear, 4" Stainless Steel MBRP turbo back exhaust, TYMAR air intake, EDGE CTS Programmer with electronic Gauges, SprayIn Liner, Bilstein Shocks, Red Head Steering Box.
2008 F32SB2 Cardinal Cameo 5er. PullRite Super 5th 18K ISP Hitch
Roger45 is offline   Reply With Quote
Old 12-30-2012, 12:58 PM   #3 (permalink)
about the only thing i haven't done is check the grounds. I know i got to do it the only problem is it's only about 10 degrees out and it sucks to crawl around on the ground like that lol. thanks for the sugestions
Old 12-31-2012, 01:37 AM   #4 (permalink)
Tanker, I am having same electrical issue. No dash lights or rear running lights. can't drive in the dark unless I turn on the flashers. Spent the day testing all the relays, fuses and light bulbs. Tomorrow going to start tracing wires for a short. Let me know if you find anything.
Mobetta is offline   Reply With Quote
Old 01-01-2013, 05:40 AM   #5 (permalink)
nothing yet but as soon as i do i'll let you know
Old 01-01-2013, 03:15 PM   #6 (permalink)
klhansen's Avatar
My Photos: (175)
I don't think your problem is going to be grounds, as they're separate for each corner of the truck.
Here's a couple of wiring diagrams that might help you out. If you're getting power out of the headlight switch, then the next spot to check is connector C1045 (should be the middle one of the 3 in-line connectors on the fender liner underneath the master cylinder). Everything goes thru there to the running lights.
Hope that helps.
92-1 Exterior Lighting.pdf
92-2 Exterior Lighting.pdf
Hard or no-start? Check Here
Old 01-03-2013, 10:52 AM   #7 (permalink)
I think I located my electrical issue, broken contact in the Power Distribution Box. Fuse 8 slipped in and out with ease. No current going past fuse.
Now I need some direction how to pull the PDB. I have the service manual but could not locate any direction for proper procedure.
Will not know until I can get this repaired for sure.
Old 01-05-2013, 09:39 AM   #8 (permalink)
i think i found mine. My uncle teasted my altenator and had the tester on the wrong setting. I should have done it my self but didn't. plus that center conection was loose so i push that back togeather. so once i get a new altenator i'll let you all know how it turnes out.
Old 01-05-2013, 03:30 PM   #9 (permalink)
well the altenator was bad, but that wasn't my problem. the truck is not telling the altenator to charge. so i've talked to a few people and they seem to think its my PCM. i think its time to go to a gauarge. ****!!!!
Old 01-25-2013, 08:29 AM   #10 (permalink)
Still have no truck but did get a suggestion from a guy through my brother. That a fuseable link might be blown. That idea compleatly sliped my mind didn't think they were still useing them at that time. Fingers crossed
Old 01-25-2013, 10:38 AM   #11 (permalink)
Another owner was having a funky head light issue and he found a short in the harness as it passes over the turbo. Apparently either the heat from the turbo melted something or something got pinched during a repair. Maybe take a look at this loom...
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, fumoto.
rock_doctor is offline   Reply With Quote
Old 01-27-2013, 10:52 PM   #12 (permalink)
Identified my Issue
Tanker it was not the connection, I found a corroded wire in the engine compartment just before it went through the fire wall.
