1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Welcome! Fill in your signature, it is easier for others to help that way.
285/75/r16 or 285/70/r17 equates to just under 33 inches and is about 11.5 inches wide, I've seen a few superduty trucks run those with no lift. I personally haven't seen 33X12.5s on a stock height truck maybe someone else has.
97 7.3 CC 2wd Dually 140,000 mi. stock except for
DIY Intake
Transmission Just Rebuilt, Tugger Kit, Billet Converter, Steel Gear Sets, Larger Cooler
I have an 'o3 4x4 and was looking for a larger tire load range E and the only thing I could locate was a Michelin 285 75R16, but they were said to be a softer compound and would not give the mileage of a more standard tire. I could find quite a few larger models in a load range D but did not want to go down thinking I would loose too much in a safety margin as far as load carrying capacity is concerned. Rolling resistance is greater due to lower max tire pressures hence lower mpg. I went from BF Goodrich AT which came standard on my truck to the Yokohoma Geolander H/Ts model . I only have a couple of hundred miles on them and can only say they are much quieter.
2003 Lariet, LB, CC. Auto, 4x4,3.73 rear end, Oilguard bypass filter, Diesel Site coolant filter, Mag-hytec Transmission pan, Century Royal camper top Turbo diesel life saver.
Just FYI, I went by the tire shop yesterday. they had 2 325/65/18's that I put on to test fit. They fit fine other than a little bit of shaving on the bottom of the plastic in the wheel well. The owner of the shop has the same truck as I have with these same tires on a stock truck with 22" rims. He did a little shaving, the exact same as I did today, so if he can fit them with a stock truck, no problem with mine with the leveling kit. I have an 06 F-250, Lariat, Crew Cab, FX4, 6.0, with 18" aftermarket wheels.
I just replaced my 43,000 mile set of BF Goodrich Rugged Trail tires with a set of 285/75 R 16-E Nitto Tarra Grapplers on my 04's stock wheels. I have no clearance issues, but I do have a 1 1/2 inch leveling kit in my truck. These tires are 8 to 10 points softer on my Durometer than the stock 4 1/2 year old spare BF Goodrich Rugged Trail. I don't know about a street tire, but 8 to 10 points softer on a race car tire mean's better traction and more wear. Only time will tell, but I wanted a bigger tire and to maintain the load range the original tires had. The original BF Goodrich tires had a maximum load of 3415 lbs. @ 80 psi. The new 285 Nittos have a maximum load of 3750 lbs. at 80 psi. These tires balanced up real nice. The biggest wheel weight that I needed to use was 1 3/4 ounces. I purchased my from Discount Tires Direct who advertise on this site.
2004 F-350 XLT,4X4,SC,Short Bed,FX4,6.0 PSD,Torqshift,3.73 LS,Red,Medium Flint Captains Chairs,Camper @ Snowplow Packages,12.5K Hitch Receiver,TT Pwr Mirrors Roof Clearance Lights
Truck born 12/21/03
Engine born 12/18/03
1992 F-150 XLT SC LB 5.0 5 Spd 227,000+ miles
I was able to fit 35x12.50's stock 20 inch wheel with just a 2.5 inch leveling kit from donahoe on my F-250. I went with Pro Comp extreme a/t's no rubbing at all.
2006 F-250 Turbo Diesel 4x4, Accufab intake elbow, MBRP 4 inch turbo back exhaust, Edge Insight Digital Gauges, 2 inch leveling kit from donahoe racing with FOX resivor shocks on all 4 corners, Stock 20 inch wheels wrapped with 35x12.50 Pro Comp Xtreme A/T's, Line X bed liner, Husky 16k 5th wheel slider hitch, Firestone air ride bags(towing 33ft 2008 Raptor toybox)
Had I known about this brand I would have looked at their Dura Grappler model. Maybe nexttime.
